Question about Westinghouse TX-47F430S 47 in. LCD TV
Tx-47f430s HDTV, but cant get the hdmi to work when hooked up to my playstion 3. It worked for only a week, then it stopped by itself when watching movie in hdmi mode. AV works but it wont detect any hdmi cables. Tried four new cables. Switched from av to hdmi plenty of times. Switched between all four hdmi slots. When ps3 is in hdmi mode, it just stays blank (no picture or sound, no function). As said before, it detected for a week, and out of nowhere, it stopped working. Any help???
  • Westinghouse Master
  • 8,457 Answers
Unplug,replug the tv about an hour later,let it reset it self back to factory setting.Go to the menu go to PICTURE go down to reset the Tuner board.All the HDMI port hubs should work again,not than, all the HDMI port hubs are shorted and dead.Must replaced the Tuner board to solved this problems.
Posted on Apr 27, 2010
  • 53 Answers
You t.v. has a widley known failure for hdmi failing
4 HDMI jacks, all stopped working at once
TV probably had a power surge, which distroyed the IC that handles the HDMI input multiplexor.
If restarting does not help I am afraid you'll have to change main board.
Board ID 48.70E01.01A or W421TAFX69 is what you are looking for.
Hope this helps!
Bobby @ coppelltvrepair
www.coppelltvrepair.com
May 13, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
No picture from dvd when using hdmi cable
make sure tv is on correct source for that hdmi input.
Jan 27, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
None of my HDMI jacks put out any sound but puts out pic, just stopped working for no reason
check sound setting on tv or audio out on the unit your trying to get sound out of
Dec 26, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
HDMI stopped working with computer
HDMI connectors are very bad soldered inside the set,not easy to resolder for an amateur ( if you are an amateur offcourse )
Other option is the HDMI cable itself.
Jul 23, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
Can not get HDMI to work on PLAYSTION 3 on my Philips 42' Plasma
I had the same thing with my PS3 on a samsung 40". Try pressing the power button down on the PS3 for 5 secs or more, until it beeps (Not sure if it's one beep or a series of). I think this is how you reset the system and it should automatically recognise and reset the resolution size to HD on you're screen. Hope this helps,
Andy.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Issue with Official HDMI cable
I don't know, did you check to see if there's a HDMI 1.2/1.3 difference? I didn't think you could hook up the two, but it may be the origin. Also, if the other cable works, stick with it...
Jun 05, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
794 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
