Question about HP Pavilion dv4000 Notebook
The back cover of my monitor is cracked. - HP Pavilion dv4000 Notebook
  • 5,603 Answers
Usually most adhesives will NOT repair this. One could glue on a sheet of material to cover and support the crack, but that is not very practical. The best plan is to replace the cover. Either get new part from HP or find a cover being "parted" out as a lot are on eBay.
Posted on Apr 27, 2010
My ViewSonic NX1932W LCD Monitor was being used as a computer monitor. It stopped working with the power button displaying the amber color. If I hold the power button it will flash blue and return to...
these monitors are tightly held in place by clips. After removing all the necessary screws, use somehing like a credit card to pry open the lid. Just need to be careful not to crack the case, or your hand.
Oct 12, 2013 | ViewSonic NX1932W LCD Monitor
I have a Nikon D70. The back screen has a crack across it. What part do I need to buy for a replacement. Many thanks Barbara
Is the crack in the monitor itself or in the cover? Either way, if you want to do the replacement yourself, you can order the appropriate part from
http://uscamera.com/d70.htm
Jul 17, 2011 | Cameras
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
How do i get the back cover off to get to the power supply? I have all the screws and the pedestal removed.
jmeyerle, Try viewing a few "lcd monitor disassembly" video clips and some "lcd monitor repair" clips at YOUTUBE first!! "PARTING" the REAR " COVER" from the front "BEZEL" hardest thing to do!!!! Don't use any sharp cutting instruments or you may incur costly trip to local hospital "ER" for 3 to 30 sutures. Protect the glass lcd panel at all times to prevent cracking it!!!! Start at "bottom" edge of case. 12fixlouie
Sep 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
How to open the BENQ G2400W LCD monitor to repair the power button that got pushed into the opening
Even if you watch 10 video clips of LCD monitor disassembly at YOUTUBE, you will not find it very easy to do!! Do not use ANY sharp cutting instruments to "PART" the rear cover from the front bezel. One carless slip and it's a trip to local hospital "ER" to be sewed back together!!! Protect the GLASS lcd panel at ALL COSTS. YOU CRACK-IT, YOU BOUGHT IT, YOU OWN-IT, TOYOTA!!! 12fixlouie
Sep 14, 2010 | BenQ FP731 17" LCD Monitor
My screen was damaged during an attempted robbery. My insurance won't cover the cost of a replacement. Can it be repaired?
If the glass of the LCD is cracked, the LCD panel have to be replaced. If you take it apart, you will find on the back of the LCD its part number. Look for it on ebay.
Aug 07, 2010 | Apple Cinema 20" LCD Monitor
Power switch
Please look through my pictures here, some time you crack it open at the bottom edge first, or from the top bezel, look for slot if it has them. Just be realcareful, do not separate the bezel too far from the chassis since the cable is really short and delicate.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 18, 2010 | Dell E207WFP LCD Monitor
LG1917S-BN Access to power supply - Rear cover removing
You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
How i can to open the cover of lcd hp L1706
1.- remove 14 screw on back
2.- remove front cover con un desarmador plano pequeño, como si pucharas hacia afuera y luego al frente por toda la orilla.
3.- quitar la base es solo con un simple apreton y click y listo, sale la parte de abajo y luego aprietas la parte de arriba y estiras. y ahi vas a ver unas tuercas te puedes ayudar con una llave española o perica pequeña.
y listo.
Jul 22, 2009 | HP L1706 17" LCD Monitor
245BW Snap/Crack sound and then does not work
Be very careful! Some monitors/TV's have 30,000+ volts DC in them even when not plugged into AC house current. The crack/snap sound was most likely an electrical component breaking down and shorting against the metal of the case of the monitor. I would take the monitor to an authorized repair center because the danger of getting shocked/killed is very possible while working on this type of problem at home.
Nov 10, 2008 | Samsung SyncMaster 245BW Monitor
HP Pavilion dv4000 Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
