Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Red light f2 - Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
  • 283 Answers
Is the rotor jammed? Free jammed rotor, check for damage to rotor and rotor housing. Is the stator wiring from controller OK? Check stator windings for correct resistance Is the rotor position sensor clipped into the stator correctly and plugged onto the controller Substitute with a new rotor position sensor.
Posted on Apr 27, 2010
Red light n green light stayong during boot blinking light on video
have you tried booting from last known good config , and if you flash your bios by unplugging yr pc and removing the cmos battery for 10-15 mins and then replacing it back then power then turn it on that shud do the trick other wise you have a hardware issue that can only be sorted by replacing the hardware
Jan 11, 2013 | AcerPower F2 PC Desktop
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
Red light comes on w/code F2 can't find manual
f2 is saying that it is a motor problem and to call a techncian here is the manual for the dd- 60 models in general as well http://www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/599732A_DD60_userguide_NZAUw.pdf if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My HPdv6910 has stopped working. I see the power light and battery light on but the hard-drive light is not on and the screen is blank even after I plugged it for more than an hour
reset boot formate to f12 but first lets get that blank screen off keep pushing f2 f2 f2 f2 thre or four times intell first page starts up then push f2 then use arrow keys on key board and at bottom booting log you shoud be set up on f2 change boot log f12 then pressf10 to save restart computer then when computer starts up push f12 then run windows under d: drive the it will ask you start windows run windows from disc or trouble shoot go to run windows after that you shoud be ok.
Feb 17, 2011 | HP Pavilion Dv6910us Notebook
I seem unable to enable my wireless capability. When enabled, the red light in the switch flashes. It did work ok up to a couple of days ago.
this light might change colour in a sequence that denotes a good connection.
you might have a hotkey function that switches the wireless on and off ,,on my pc it is Fn-F2 but all pc's differ
Sep 10, 2010 | Acer Computers & Internet
How do u turn on and use wifi on Inspiron B130?
There should be a wireless icon next to the time (lower right hand corner of your screen) that you can right-click on and Turn radio on. Hit the function(blue button lower left) and F2 if there is a tower on F2, it may be a differant F number on the top. If that doesnt work, right click my computer and click manage. Then Device monitor, and then click the + next to network adaptors and make sure the wireless symbol doesnt have a symbol on it besides the green chip. If its red its disabled, right click enable. If its yellow you need a driver for it, find it on Support.Dell.com and install the driver.
Jan 11, 2009 | Dell Inspiron B130 Notebook
DS Will Not turn on. No power
Does the power light turn orange or red for half a second when you plug in the charger then turn off? Is that the ONLY activity you can get?
Then...
Fuse F1 and/or F2 is blown on the board. Easy fix if you have the tools and know how to solder.
Jun 25, 2008 | Video Game Consoles & Games
F2 FAULT AND ALL LIGHTS ARE FLASHING.
f2 means water in the flood pan remove dishwasher from under bench and tip back the water will run onto the floor.then test the dishwasher while it is still out you can remove the rear panel were the hoses go through and check the drain hose for leaks also check the white plastic ring under the metal filter for cracks,they look like a dark line.as far as the dispenser the most common cause is the main board,remove door skin and control panel and check the back of the board for damaged tracks,you will also have to replace the wax motor(red) on the drying fan(if fitted)check the solenoid on the dispenser for open circut.hope this helps.Ian.
Mar 17, 2008 | Asko D1876 Dishwasher
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
130 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
