Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled. Doesn't matter if we are faxing one page or multiple pages.
Posted on Jun 24, 2010
Fax memory full lexmark x
Memory full, cannot send faxes
The printer fax memory is full. Press the check mark button to clear the message and cancel the fax.
• Reduce the fax resolution and try to send the fax again.
• Reduce the number of pages in the fax and try to send the fax again.
http://www.edvdrucker.de/Downloads/Handbuch/Lexmark/Lexmark-X254-User-Guide.pdf
Jul 09, 2014 | Lexmark X364dn All-In-One Laser Printer
I can't clear the Fax memory it say I have full memory. Tried * 3 & * 9 and nothing clears this message and I can't receive faxes
  1. Press the Setup button (c01361401.gif ).
  2. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button (c01235250.gif ) to exit.
Jun 16, 2011 | HP J3680 Officejet All In One Printer
Hi Geo Group,
To clear the memory try the following:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
Eliteprintersolutions@gmail.com
Jun 24, 2010 | HP LaserJet M1522nf Multifunction Printer...
What does NG mean for Status after sending a scanned item or faxed item?
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
Thanks.
Jun 25, 2009 | Toshiba e-Studio237 Grayscale Copier
Error message on my Hp Officejet J6480-Fax log full
  1. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  2. Press the Right arrow button (c01185072.jpg ) until Fax Log displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  4. Press the Cancel button (c01235250.gif ) to exit.
Hope this helps
Feb 23, 2009 | Digital Products Hewlett Packard OfficeJet...
Can't receive or send faxes
In case you haven't solved this yet:
  2. Press the Right arrow button ( > ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button ( > ) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button ( > ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button ( X ) to exit.
You can go to this web page also:
Fax Log Full Message
Thanks for using Fixya.
HP6450 says fax log is full and cannot recieve or send.
  1. Press the Setup button (c01361401.giftools ).
  2. Press the Right arrow button (c01185072.jpg> ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg >) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button (c01185072.jpg> ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
Jan 20, 2009 | HP DeskJet 6450 Printer
The screen keeps on showing " memory full".
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 21, 2008 | Brother IntelliFAX 560 Plain Paper Fax
OUTGOING FAX ERROR CODE: NG
To do this:
and MEMORY TX: ON?
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Memory full
Canon has an excellent on-line trouble-shooting guide. Here is a link to your product. http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=241&modelid=11736 Click on Step-by-Step Troubleshooting under the Tech Support section. This guide suggests the following for clearing out the memory" Print or delete documents in memory and ask the other party to send the fax again. Refer to the following to delete transmission jobs reserved in memory. 05SH01024_EN_01 How to Cancel Reserved Jobs 1. Press [Add. Mode] twice. 2. Use [Up/Down] to select [6 CANCEL RESERV.?], then press [Set] ([OK]). 3. Use [Up/Down] to select the job you want to cancel, then press [Set] ([OK]). [MEMORY]: Documents in memory [TIMER]: Timer sending [B-CAST]: Broadcasting [POLL-TX]: Polling sending [POLL-RX]: Polling receiving [RELAY]: Relay initiation Press [Right] to view the job. 4. Press [Set] ([OK]) to confirm canceling the job.
Oct 12, 2006 | Canon L120 Fax Laser Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
489 people viewed this question
Seeker5211
Seeker5211
