Question about Maytag 7.0 Cu. Ft. Electric Dryer
After moving to a new home my wife says the dryer doesnt work like it supposed to. "Its hot but not dry."
    Novelist:
  • 145 Answers
It appears that moisture is remaining in the dryer and not being vented. Check your vent pipe for leaks and sizing and make sure the run on the vent pipe to the outdoors is not too long (over 6 feet).
Posted on Apr 27, 2010
Testimonial: "I didn't think there could be a clog but the exit vent on the outside of the house has a catch for lint as well. My old house did not. live learn."
Kenmore series 80
Yes a wire may have come loos or the element has move slightly. although a screw is supposed to hold the heating element. it is possible that it slipped out first.
Jul 27, 2014 | Kenmore Dryers
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
It gets hot but doesnt dry
you will need to remove the front cover,by removing 2 kick panel screws at the base of the front of the machine,remove front cover and make sure blower wheel is turning,if so,then remove any heating ductwork and vacuum out all lint,this sounds like a restriction inside the machine for air flow
Mar 05, 2010 | Whirlpool Inglis IP8200 Dryer
My electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Jan 25, 2010 | Kenmore 63942 Dryer
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Dryer doesnt get hot enough to dry within sycle anymore
I have the elite he4 and just recently moved and mine did the same thing I found that the heating element had sliped out of its proper location was still connected but wasnt seated right
hope this helps
lhendrix
Mar 30, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
80 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
