Sansui 5500 volume control
I need a potentiometer for a sansui 5500 receiver. It is 250K ohm (B) 2, the original stock number was 1010510. I'm having a hard time locating one. Anyone know who would have one or know of a new substitute that would work?
SOURCE:
petraman7
  • 1175 Answers
SOURCE: Sansui 5500
Yes. You can get replacement bulbs and no , it's not difficult to get the case off. Most likely 4 screws on the sides and a couple on the bottom
Lamps at
http://www.vintage-electronics.cc/
or www.partsexpress.com
Posted on Feb 24, 2008
jerryg50
  • 1691 Answers
SOURCE: need a volume and balance
If this is an older unit, Samsung is no longer supplying parts for older units. They were bought over and it is no longer the same company.
You will have to send the amplifier to a shop that can do custom work and retrofit a new set of pots to the amplifier. They will use industrial parts and modify them to mechanicaly fit.
Jerry G.
Posted on May 04, 2008
  • 123 Answers
SOURCE: fuse size
I don`t know the machine but if you`ve got a multimteer or an ammeter, connect the meter across the fuse connector and read the current. If it reads 200ma, fit a 250ma fuse into the socket. If you give it about 50-100ma above the reading, you`ll be fine. Ian
Posted on Jul 30, 2009
SOURCE: Sansui G-7700 digital display
Funny that you just posted. On Monday, I dropped off my G-7700 at The Audio Lab in Harvard Square, Cambridge, MA. http://www.theaudiolab.com/
As soon as I walked in the place I knew I was at the right spot. They service and sell some really high-end vintage units as well as carry brand new high-end audio equipment. $60/hr for service work. As a gauge, my G-7700 took 2hrs to do a complete overhaul, which included replacing some pots, re-soldering cold joints, calibrating the tuner and other components. i thought it worked really well before!
Experienced, knowledgeable, efficient.
Give them a call and ship your G-7700 to them. It's worth it.
MRE
Posted on Feb 24, 2010
  • 2337 Answers
SOURCE: I have a sansui G9700 receiver/amp. The volume
The potentiometer doesn't need to be replace, it has collected dust inside causing the intermittent operation. Buy a contact cleaner/conditioner to spray inside it and move the potentiometer clockwise and counter clockwise a few times until the dust inside it is gone.
Check this link to find a contact/conditioner cleaner or you can try spraying rubbing alcohol but this could because alcohol doesn't not lubricants properties.
Let me know if you require further assistance.
Posted on Nov 27, 2010
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Sansui 7070 receiver Hum
Your filter capacitors in the power supply section are to blame and they need to be replaced.
Mar 30, 2014 | Sansui 221 Amplifier / Reciever
I have a sansui G9700 receiver/amp. The volume control works intermitantly. Must play with it to get volume. I believe I need to replace the potentiometer F3085. where can I get one? Erick G
Nov 27, 2010 | Sansui Audio Players & Recorders
Sansui AU-7500 volume control problem - need replacement
Hi...
Is that the fancy pot with more than 6 leads..kinda square looking?
This place has some.
http://angela.com/
Rate my help if this helps...Thanks
Mar 11, 2010 | Audio Players & Recorders
The model number for the remote is Sansui DVR 810
Try this website 1-800-Remotes Factory Original.Use ur DVR box as the serial number.They have everythings link to TV- VCR-DVD,and more all remotes.
Oct 22, 2009 | Televison & Video
Require potentiometer for old sansui amplifier. Sansui part number 46159900. This is the number on the edge of the potentiometer. Not sure what the ohmic value is.
You will have better luck finding it if you describe what control it is and what model it is from. Can you please update this with that info?
Thanks,
Dan
Aug 29, 2009 | Audio Players & Recorders
I have a Sansui 4-channel receiver QR-4500, there is alot of fuzz in the sound. When I turn the volume control up or down there is fuzz, also when I use the balance controls there is fuzz. The front left...
Mike,
It depends on how you intend to use it, your technical skills, and how much money you're willing to put into it. If your intent is to use it with a LCD / Plasma home theater system, you would be better off purchasing a new receiver.
If you want to keep it for some other purpose, and have the technical skills and tools necessary to repair it yourself, I would recommend purchasing a service manual for your receiver.
The other alternative is to find an electronics repair shop and get an estimate on what it would cost to fixt it.
In some cases, problems such as fuzz in the volume and balance controls, can be fixed using a high quality non corrosive electronic contact cleaner. This type of "possible" repair works best with potentiometers. However, there's no guarantee contact cleaner will correct the problem. It may be necessary to replace the components.
If component replacement is necessary, the service manual will be an invaluable asset when it comes to finding a compatible replacement part.
I can understand why you might want to get it repaired as I'm a fan of Sansui, Nakamichi, and other like equipment. I currently have a Nakamichi receiver that has the same problem with the volume and balance controls. At some point, I'll take the time to repair it.
For now though, I purchased a new receiver to connect to my home theater system and I'm actually glad I did as the new receiver is more compatible with the hardware available on the market today.
Aug 21, 2009 | Audio Players & Recorders
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Nov 19, 2007 | RCA RCR311B Remote Control
100 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
