Question about Lexmark X5470 All-In-One InkJet Printer
Paper wont feed - Lexmark X5470 All-In-One InkJet Printer
  • 4,041 Answers
Hello there You can try this may work.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Power light blinking paper wont feed through
Unplug the power cord from the printer (top left side). Hold the paper feed button while plugging the cord back in.
Jun 29, 2010 | VeriFone 900 Printer
Same problem. Printer runs but wont feed in any
observe if pick up mechanism function as when you send printing job. if yes, may pick up roller already worn out and need replacement.
Jun 02, 2010 | HP Officejet 5510 All-In-One Thermal...
Will not feed the paper. I checked the feeding clutch and it looks fine. But if I activate the solenoid by hand still the paper wont feed, the feed roller wont activate. If I manually activate the solenoid...
check or replace the big white gear......that goes with the solenoid,the inside of that gear should have a little spring...if its mising get another gear.....good luck
also check the shaft with the
Aug 03, 2009 | HP LaserJet 1300 Printer
Paper wont feed
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
Apr 24, 2009 | Office Equipment & Supplies
PAPER WONT FEED IT KEEPS PULLING TO ONE SIDEANS WONT FEED
I have a HP Photosmart A626. The paper won't feed. It seems like something is blocking it and sometimes takes me 5 minutes to get it in where at that point the paper is ruined.
Chris
Apr 18, 2008 | Office Equipment & Supplies
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Epson c20ux paper wont feed into printer
you wont have to feed the paper just try to print and it'll feed the paper automatically. but if there is a problem in mechanism that will be your problem, you'll have to bring it or just call a service tech.
Sep 08, 2007 | Epson Stylus C20UX InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
592 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
