Question about Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
The chuck on my old Hilti TE 60 is stripped.
The collar keeps popping off and wont tighten down on the base. Hilti says there are no other chucks that will fit. Can I buy the part used or is ther something I can use.
If you can t find the cap nut, drill 2 small holes on either side, tap the holes and put in 2 set screws to hold it in place
Posted on Jun 11, 2010
    Scholar:
  • Hilti Expert
  • 123 Answers
Are you talking about the cap nut that threads onto the chuck? It is very rare that it would strip out. Word of warning if you do find one and thread it back on. You need to have a chisel in the chuck and have the chisel end locked in a vise. This protects from breaking the gear housing on the inside where the shift dog rides up and down.
Those parts are no longer available but you can still find some used on Ebay. Also the TE-72 used the same chuck parts.
Posted on May 07, 2010
While using the hammer drill the chuck came off and I cannot get it back on.
Wipe the spindle off and in the back side of the chuck. The back collar is spring loaded and should move freely, if not I would use some lubricating fluid until the collar moves, with that said when you reinstall pull on the back collar to release the locking steel balls and push on spindle then release the collar and turn it until you feel the steel balls click into the indents on the spindle. Let me know if you need more assistance.
Aug 16, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
The chuck on my Hilti TE 24 hammer drill keeps falling off. I doesnt appear to be anything broken. Either there is a missing snap ring or I am just not putting it back on correctly. Any suggestions?
the header list 2 different drills, if yur chuck has a colllar with a quick release, I would suggest thoroughly cleaning and then using a lubricant, usually there are steel balls that lock into detents in the spindle and they might be stuck the collar should move freely.
Sep 25, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
How to disassemble a te 60 , the chuck end. Its not worth sending to factory but i might tackle it myself it does not hammer all the time and does not rotate all the time
Hilti no longer services the old TE60. If yours is a metal housing here is how you disassenble the front end.First you need to put a flat bladed chisel in the chuck. Then lock the chisel in a vise. Next you put a pipe wrench on the chuck cap nut. That is the piece on the end of the chuck. Using a cheater bar turn the nut off counter clock wise. You then can remove your chisel, the cap nut, an oring and the locking sleeve with two rollers. This will expose the chuck that is held in place with 8 5mm allen screws. After that you have a large snap ring to remove before pulling out the rest of the front end assy.
Jul 18, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
How do you change out the chisel on the Hilti TE 76P?
Pull back on the chuck head and turn it. The Chisle should fall out.
Oct 25, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Have a te6c and the chuck fell off- how to put it back on? looks like may require a large vise to press it on?? phil
pull back on the collar of the chuck and slide it on and then release the collar and turn till it locks onto the spindle.
Oct 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
HI I AM USING A HILTI TE16c AND THE HEAD WHERE YOU PLACE THE DRILL BIT OF THE DRILL HAS FALLEN OFF CAN YOU ADVISE HOW TO PUT IT BACK ON
this is an easy fix. it designed to come of easily and can fall off if you dont tighten the side handle. the chuck has a quick release mechanism. place the chuck onto the machine as far as you can. it wont go on all the way. simply pull back the black collar on the chuck toward the front of the chuck and push the chuck on the rest of the way.
to ensure that it is on correctly, turn the chuck by hand until it locks into place.
Hope this helps.
Aug 15, 2009 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
426 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
