Scanner problems I am using a cannon DR 3080CII scanner and when I go to scan with the program Capture Perfect 3.0 i get not responding every time. I have removed and reinstalled the drivers and the program several times and still the same result. Please help.
  • jenkinsclan4 Jan 05, 2009
    I recently bought a Canon DR-2080C on ebay. I downloaded Capture Perfect 3.0, but keep getting a program not responding error. Any help would be appreciated. Thank You!
mohanchennai
  • 490 Answers
SOURCE: Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Posted on Dec 11, 2007
mohanchennai
  • 490 Answers
SOURCE: Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Posted on Feb 21, 2008
  • 103 Answers
SOURCE: New Computer; Windows VISTA; Scanner
go to device manager and make sure that the device is working properly because if the driver for the scanner may be missing and you will have to acquire it to use your scanner. if you need anything else please feel free to leave a comment.
please rate me. thank you.
Posted on May 28, 2008
  • 905 Answers
SOURCE: getting my 4050 scanner to be the default scanner
in the software settings or preferences you should be able to make it the default and if you have another scanner you will have to make sure it is not the default sscanner in its software settings
Posted on Oct 08, 2008
mohanchennai
  • 490 Answers
SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Posted on Mar 28, 2009
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
Canon DR-1210C scanner does not work with Capture Perfect software
you can download and Install Twain driver for this model and you can scan from Any Image Editor like photoshop and Acrobat PDF editor
download link http://www3.canon-asia.com/downloads/drivers/dr/DR1210C/DR-1210C%20Driver1.1.zip
Feb 06, 2013 | Canon Office Equipment & Supplies
When scanning, there are lines on the image I have scanned.
Use a blank sheet of paper (as white and clean as possible). Put it in the scanner landscape ( you will need to cut off about 1/2 inch of the paper to make it fit. The run the DR-3080CII Shading tool (DR3KUserSh.exe) C:\Program Files (x86)\Canon Electronics\DR-3080CII\DR3KUserSh.exe
May 19, 2010 | Canon DR 3080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
The cannon DR 2580-C resinstalled to new computer
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
S. Mohan, Chennai, India
Feb 21, 2009 | Canon DR-2580C Path-Through Scanner
Transfer scan settings from one computer to another?
You need to do it only once! Capture perfect remembers the previous setting. If you install Capture perfect in another system it will be only in the defalut mode. You cannot transfer the settings
S. Mohan
Dec 02, 2008 | Canon DR-7580
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Jun 18, 2008 | Canon DR-9080C Path-Through Scanner
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
