Question about Kenmore 22812 Bagged Canister Vacuum
Brush not moving, suction working
Motor runs, brush does not move. will replacing the belt help? if so, where is the belt that needs to be replaced located and how do I know which belt to buy?
  • 50 Answers
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Posted on Apr 27, 2010
Testimonial: "Very helpful-lots of details and things to look for to rule in or rule out a problem-thank you!"
I have a dyson dc 28. The motor runs but the brushes don't turn. The on switch flashes
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc28
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 26, 2017 | Dyson Vacuums
Dyson dc35 Brushes quit turning after a few seconds--motor keeps running. It does this consistantly. No red flashing lights.
https://www.thinkcrucial.com/search?type=product&q=dc35
Ava B.
Nov 22, 2016 | Dyson DC35 Handheld Vacuum
I'm getting no suction and the brushes are not rotating
Hello! If you are using the cleaner on carpet, it is necessary for the brushes to rotate to assist the motor with maximum pick up. If your brushes are not spinning check the belt to make sure it isn't broken or stretched. The belt will need replacing about once a year. Below are steps for checking the belt on your U5399-900.
1. Place handle in low position and turn cleaner over so bottom side is up.
2. Remove the 4 screws. Lift off bottom plate.
3. Inspect the belt for rips and tears. If it is damaged in any way, broken or stretched replace the belt
This unit takes belt 38528033. Be sure you replace belt with genuine Hoover parts. Here is a link where you may go to order a replacement belt.
Service Center Locator
Hope this helps!
Jun 05, 2014 | Hoover U5399-900 WindTunnel Lite Upright...
DC17 suction motor stopped
It could be that your cyclone needs to be replaced. Depending on how the unit was cleaned (the cyclone in particular). Some people who service these machines wash the cyclone with out completely dismantling it, they just fill it with water and shake stuff out of it. This can cause debris inside the cyclone to become lodged causing clogs. If after checking for clogs and if your changeover valve is working (the piece that moves back and forth on the side of the machine when you pull the handle back to vacuum carpets) and the machine is in the upright posistion and the hose doesn't work, then you probably have a cyclone problem.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 10, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi I have a dirt devil vision. Hose works, but does not vacuuming the floor. Belts are not broken. Larger belt is moving, smaller belt that moves the brushes does not.
hi krueger, sorry for the problems but hers an idea how about turning on the vacuum and put your hand under the part where it sucks uo the dirt off the floor and i guessing you would have a little suction, since the brushes are not moving its going to not pick up as well as it should my guess is that the belts need to be replaced even if one is moving, i would change both belt to be sure and also are you smelling a burning smell if so then that would prove fact to needing new belts, hope this helps, Jamie
Dec 14, 2012 | Dirt Devil M086700 Vision Bagless Upright...
Bissell 3750 brush not moving has new belt suction works well on vacuum
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Sep 17, 2011 | Kenmore 22812 Bagged Canister Vacuum
My Bissell Model 3760-4 is not working properly. The belt has been replaced (and checked 3 times), but the brush bar does not move when the brush motor button is on. The little metal turning piece that...
Ava B.
May 12, 2017 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction-all lines and filter are clear
If the motor runs, check the following:
Remove the beater brush and clean as best you can. At either end of the brush is a plastic holder that positions the brush in the vacuum body. Add some WD40 to the space between the plastic and the beater brush and turn by hand to be sure they move freely. As long as you have the beater brush out of the vacuum, replace the drive belt.
If you find this solution to be helpful, I would appreciate a Thumbs UP rating from you. Thank you. Paul
Oct 08, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Kenmore 22812 Bagged Canister Vacuum Logo
341 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
