My DVD player will not read DVD's. I tried running a cleaner disc, but it won't read that either. What is the problem and how can I fix it? Thanks!
    Genius:
  • 1,112 Answers
Hello:
There are different causes as to why your system will not work, The most common failure in DVD/CD players is the spindle motor, If the motor does not spin at the right speed then the pickup lens or laser as its called will not be able to read the TOC(Table of contents). This motor has to spin at a predetermined speed and send its rmp back to the system control for the unit to work. You should consider replacing the Mech assembly as its called it will include the spindle/Stepper motor and gears and the new laser.
Posted on Apr 27, 2010
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
My Sony DVD player will accept the DVD but fail to load and play the DVD?
Unfortunately , Some DVD players ,especially brand ones cant read some DVD s and
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
Thanks
Jul 25, 2011 | Sony RDR-VX500 DVD Recorder/VCR
After inserting dvd in player it reads no disc
Just in case,quick remedy ,
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
Jul 21, 2011 | Daewoo DV-6T834 DVD Player/VCR
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
DVD problem
It could be a couple things...
#1. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
2. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
Let me know what happens after you get the DVD laser cleaner and run it. Hope this helps.
May 07, 2008 | Televison & Video
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
