When I boot up my computer it has been making a "whirring" sound and vibrates - even my desk vibrates. Any ideas as to cause and solution?
  • Marjorie G. Morgan Apr 27, 2010
    Thank you so much. I did find a disc in the tower that I had forgotten about. Boot up is smooth as silk now that I removed it.
    Marge
  • Marjorie G. Morgan May 01, 2010
    Thanks for helping me fix the problem. Your solution worked like a charm!
  • 355 Answers
Sounds like you have a cd in the cd-rom drive that the pc is looking at as a potential boot device. remove all cd's from the drives before you boot up the pc and you should get rid of the problem. If you really want to you can open the cover and make sure the screws to the cd-rom drive have not come loose.
Posted on Apr 28, 2010
  • 666 Answers
Sounds like your hard drive is running really rough it is normally the cause of any noise or vibration as its the only moving piece on the computer however if you have a cd in the drive it could be causing the problem as well but my first guess would be the hard drive or heat sync no way to know with out opening it up and giving it a nice compressed air shower I find once every other month works wonders for noise and heat issues it may be your hard drive needs to be replaced hopefully before losing any valuable data
Robb
Posted on Apr 27, 2010
When I turn into a parking space or onto a street it sounds like something clicking or vibrating even when i push my clutch in
Most clicking/popping noises when turning indicate a bad ball joint in the front axle. The CV joint has a boot over it that will eventually rip, causing the grease inside to be slung out. Dirt and moisture will get in there and cause the smooth joint to pop when under stress, like turning.
Mar 19, 2014 | 1999 Honda CR-V
Roaring noise front end
sounds like wheel bearings
Sep 01, 2013 | Mercury Cars & Trucks
Why does my computer make a loud whirring sound
Could be either one of the cooling fans or CD/DVD drive. Put your hand on the outside of the disc drive, if it isn't vibrating then it's a system fan. Replace it.
Dec 25, 2012 | Compaq Evo D500 PC Desktop
I am hearing a noise, like a whirring sound that speeds up with the acceleration and makes no noise when in park. Does this sound like cv joint trouble?
a whirring sound can be a bearing on a component under the hood.(power steering pump,alternator,idler pulley bearing,etc),it can also be a serpentine belt from a worn belt or belt tensioner a cv joint won`t make a whirring sound(it will cause a clunking noise or a vibration).
Mar 24, 2011 | 2004 Pontiac Grand Am
My Asus netbook won't power up at all. The last time it powered up I was able to login then I heard a whirring sound and the screen went black. Now there are no lights whatsoever on the netbook.
The whirring sound came from the hard disk - either it has died or thepower sent to it was too little to make it work .
Remove the battery and try to boot in the BIOS with the netbook attached to the charger - if you can't do that then you have a hardware failure. Remove the hard disk and try again - if it fails even now then the motherboard is gone.
Aug 24, 2010 | ASUS Eee PC 1000 Notebook
ACER desk top computer does not start When I press the start button the light comes on the computer whirs for about 1 sec and then turns of. or nothing hapens. desktop ACE aspire ASX3200 8550 B1
There could be tons of reason for a computer not starting up! the first thing I would replace would be the power supply, then the memory sticks or even the entire motherboard could cause it. does the computer beep any tones when you first hit the power supply, no? replace the power supply unitassy.techman
May 08, 2010 | Computers & Internet
My laptop wont boot. It makes a loud whirring
take whatever CD you have out of the CD/DVD drive. You might have the boot order set to CD first. If that's the case, it's trying to boot from your CD drive instead of your hard drive.
Feb 19, 2010 | Toshiba Computers & Internet
Faint noise on booting.
Try this remove side cover and boot computer listen for any extra noise fan etc. also by power supply
As I think you have a bad bearing in a fan
To temp fix it
remove paper cover over center of fan and put a small and I mean small drop of light machine oil on bearing then replace paper cover.
check if this stops the noise if it does you know which fan to replace.
If it is power supply fan and if you think yourself capable remove fan and do the same to it
Oct 13, 2008 | Intel Motherboard
Simpletech 320gb hard drive
the hard drive inside of the external device is damaged. probably the drive head scratched one or more of the platters inside of the drive. this is a common occurance with laptops and computers when they take a dive off of a desk.
need to either get a replacement drive or another external hard drive.
Jun 21, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
David Payne
David Payne
