Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Eats mower drive belts
My DLT 3000, purchased in 2006, has never given me any problems, each year I remove the deck, clean it, check and replace bearings as necessary, but this time, when I put it all back together, it ate the belt! So I go buy a new one, it ate it too!!, I removed the deck, checked everything, put on another new belt, mowed for 15 minutes, and started to smell rubber burning, so I stopped just before it spit the belt off. What in the world is going on? Idler pulley bearings are ok, both blade pulleys, bearing and shaft are ok, I did replace a pulley prior to operation this year, maybe it's messed up??
  • 54 Answers
You say you checked everything. I would remove the deck and belt and physically make sure both blades spin freely. Then I'd install the belt and check again, it sounds as though each component works fine alone but when in conjunction with other parts something is binding. Good luck
Posted on Apr 28, 2010
DLT 3000 25 OHV belt keeps breaking
In this parts diagram notice idler pulley #145. Its the spring loaded moveable puller. Make sure that it's mounting is tight and and that it runs true. If the pulleys don't stay in alignment it will cause trouble.
http://c.searspartsdirect.com/lis_png/PLDM/P0412015-00010.png
CRAFTSMAN Lawn Tractor Parts Model 917275820
Check out youtube for help videos.
mower deck belts breaking YouTube
Oct 04, 2014 | Garden
Need drive belt diagram and instructions for replacing the drive belt on a craftsdman dlt 3000 lawn tractor.
Your mower will have a model number like this one:
917.275820 The pictures in the manual below are for the 18.5 - 20 Hp 42 inch deck riding mowers.
It brings up this manual: (3.71 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0411347.pdf
See page 23 under service and adjustments for deck belt routing picture.
Thanks for choosing FixYa,
Kelly
Jul 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
Routing Of Deck Belt For DLT 2000 48 inch Deck
It can be found on amazon, here... take a look Amazon com DLT 2000 belt. I hope this was helpful. Have a nice day
Nov 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Hi, I have a westwood ride on mower & the 3 bladed 36inch deck has started to whine bearings I think? Are they easy to change? special tools? parts off who? the machine is just 3 years old Thanks JT
I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
Sep 20, 2009 | Garden
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace drive belts on mtd model # 136L660G205
Remove the entire mowing deck so you can easily see the drive belts. Clean up everything and purchase new belts. Now take a picture of the old belts in place and then remove one at a time and replace it.
Apr 30, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
324 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
