Question about Canon PIXMA MP130 All-In-One InkJet Printer
Cartridge jammed. I have a message that says cartridge jammed.How to fix it?
  • 4,041 Answers
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
How do I fix a cartride jam?
Have you tried
(1) running "print clean" or something like that?. (If you don't know how to do that, check your manual).
(2) Removing cartridge/s and installing again?
(3) Cleaning head by dabbing lightly with Q-tip in isopropyl alcohol?
Other possible solutions depend on answers.
Sep 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Tip
My 2710 All In One keeps giving an error message that the printer cartridges are...
Is your cartridge clogged,,,
Then in the maintenance settings in PRINTERS AND FAXES,, do a deep ink cleaning,,
If that fails then blot the cartridge on a piece of tissue damped with alcohol.. or let the cartridge sit in some rubbing alcohol for a cpl or minutes and then blot it..
As a last resort if the above fails,,, WARNING NOT A CONVENTIONAL METHOD
try boiling the cartridge for a few minutes,, MAKE SURE THE WATER IS BOILING BEFORE U PUT THE CARTRIDGE in.. so to to remove most of the air from the water to prevent corrosion
on Dec 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Cartridge Jam
hi
i assume you have got the correct cartridge for this model of printer.
i also assume that you have correctly synchronized the cartridge heat to its coupling structure in the printer.
if you have fixed it correctly and it still sticks out, the cartridge could be defective, in which case try and replace the cartridge from the vendor.
cheers
Jul 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Apr 10, 2009 | HP Photosmart C4580 All-in-One InkJet...
Cartridge Jammed
Try removing the print cartridge and then insert it again this should clear the problem.
Feb 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Print cartridge stuck
Hi please click on the link below to know exactly what you need to do to fix paper jam problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09128&lc=en&cc=us&lang=en&rule=1823&product=77146&dlc=en
Please let me know if it fixed the problem or not.
Cheers
Jun 10, 2008 | HP PhotoSmart 7960 InkJet Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell 1600n Cartridge Sensors messed up
the cause of this problem is a little spring sited in left side of feed sensor´s actuator and keep it on it´s right position: sensor actuated(off);if this little spring is out of position,feed sensor´s actuator go out of position and machine´s main board detects high(on) signal showing a paper jam message.
May 30, 2008 | Dell 1600n All-In-One Laser Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
96 people viewed this question
old marine
old marine
