Some of the channels doesn't have sound - Televison & Video
  • 70 Answers
Look for SAP in tv audio menu on channel that have no sound. put it back to MAIN.
Posted on Apr 27, 2010
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
Program local channels
just search automatically the local channels(scan)on your search mode.click asia pacific region or just asia on your menu.but don`t forget to set it to auto system and the sound for ntsc3.58 system so that you can get clear sound.or your antenna doesn`t install correctly?please check it first
Jan 31, 2014 | Orion1934 19" TV
Sirius radio
It sounds like your radio lost it's subscription code. Go into settings are reenter your code. You can call serious if you don't have it.
May 23, 2013 | Audio Players & Recorders
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I...
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
Jul 21, 2012 | Televison & Video
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me abigail@nkaditelecoms.co.za
An upgrade can be offered, with lower call rates.
Jun 13, 2017 | Lands Phones
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have not received a diagram of my stylus wiring. none of the sites that was recommended have helped. do you know the purpose of each color of the four wires?
One is earth for the right, one is earth for the left, one is right channel and the other is left.
You don't need to know the colours to find the left and right channels. Just connect the turntable to the amp switch on. Then with your finger touch each wire one at a time. One will buzz on the left the other will buzz on the right. You might even get a slight buzz from the two earths.
The cartridge might have the left or right channels marked so you can connect them, but if it doesn't just connect the left to one side and the right to the other, then do the same with the earths. try it out, if the channels are the wrong way round change them, if the sound doesn't sound right change them again and again till it sounds right. You won't damage the amp or cartridge from doing this. Unless it's some kind of static effected cartridge!
Jul 30, 2011 | Audio Players & Recorders
Channel dial only works one way going down channels and will not go up any ideas how i can get this working please
that is an odd issue. each slot on the dial is a specific freq. meaning theyRAM h spot the non clicks I to is always going to be that channel. the channel selector sounds like it is bad. you can try contact cleaner on the selector knob. if that doesn't fix it you need to replace it.
Jun 30, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
