Question about Motorola Mobility RAZR V3
Auto Answer I do not want my cell phone to automatically answer the phone when I open it. I cannot find the feature where you can set it to not answer unless you want too. Also, how do you make the fonts bigger so that I can see who's calling. Thanks.
  • 4 more comments
  • Anonymous Aug 19, 2018
    goodhttps://www.google.com
    google.com/
    Yeah, I had this same problem, but it's solved now. I will tell you that I solved it by visiting the brillassignment review site, but I can't tell you which article was it that gave me the solution, because frankly, I don't remember it, at all.
  • Saeed Khatri
    Saeed Khatri Feb 09, 2019
    I have been searching to find a comfort or effective procedure to complete this process and I think this is the most suitable way to do it effectively. magzine post fashion
  • Anonymous May 14, 2019
    It actually depends on the type of phone you had and the make, if you had a java enabled phone, chances are you cannot make the font bigger, or you can try official random number generator
    to find your luck
  • Jombells Flower
    Jombells Flower May 14, 2019
    Auto answer is a feature that is very common in every phone, you try this solution, go to settings, and find answering options, deactivate auto answer you can do this until you get it right watch game of thrones
  • Anonymous Jun 10, 2019
    I think all of your concerns are found on Settings. I suggest you explore your phone also. It is kinda therapeutic sometimes. :)
    www.homestaginginmiami.com
  • 31 Answers
Hello PattiPaige,
The feature to disable answering the phone when you open the flip can be found under:
Settings & Tools
- Call Settings
- In Call Setup
- Answer Options
- Set option to Off
This will disable the flip from answering the call when opened.
As for increasing the font size, i don't believe there is an option to do so. If I become aware of one I'll try to get back to you on.
Hope this helps,
cHiPz
Posted on Mar 24, 2008
    Problem Solver:
  • 9 Answers
Chk it on network settings or call settings, Disable answering machine or auto connect
Posted on May 14, 2019
    Habit-Forming:
    New Friend:
  • 13 Answers
Depending make and model of your phone.There should be a setting to activate on the phone to allow any incoming calls to be answerd if you press the (green)handset sighn key only.
Posted on Feb 09, 2019
    New Friend:
  • 29 Answers
This audio device works for the best thing by Windows 10. The main http://windowstuts.net/connections will be on the Windows site. It guides to manage your Windows Mobile with Bluetooth and other wireless connections
Posted on Nov 28, 2018
  • 807 Answers
To get to it press the middle button at the very top of the keypad.
Settings > In Call Setup > Answer Options > Open To Answer.
Change setting.
Not sure if you can change the font/text size.
  • 32 Answers
In your phone enetr Settings-Call settings-answer options-open to answer - turn on/off
About the font size i don't know
You have an option calld Pesonal adjusment or somthing like that then Change display from icons to list, that's what i know
hope this helps
and
  • bono bono1
    bono bono1 Mar 24, 2008
    thanks to Yuval Vardi who gave me this answer
SOURCE:
How do set auto answer feature?
What make and model is "this" phone?
Jan 12, 2013 | Cell Phones
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
How do I turn off the automatic answering feature on mu Samsung s3500
hello,
1. go to the menu,
2. select the settings,
3. select call settings,
4. you'll see the answer option,
5. turn off the auto answer,
take care
May 30, 2010 | Samsung S3500 Cell Phone
? auto answer?
1. Messages
2. Settings
3. TXT Auto View
4.a. On (Will display text automatically, no readout)
b. On & Readout (Will display text automatically and read text automatically)
c. Off (When text is recieved, option are given to view text now or later, read out will not happen automatically)
No Problem
Jul 31, 2009 | LG VOYAGER VX10000 Cellular Phone
Auto answer cell phones
the lg voyager as the auto answer feature.
May 08, 2009 | LG Incite Cell Phone
Turn auto answer off?
You probably have auto answer turned on in your phone. The headset does not have this feature. You must find it in your phone to turn off auto answer while headset in use.
ps- second user- You canot use the phone handset with bluetooth device on. At least none that i know of.
Feb 25, 2009 | Jabra BT350 Bluetooth Headset Headset
Sony 610i automatic answer
Auto answer only works in conjunction with a handsfree device
Nov 09, 2007 | Sony Ericsson K610i Cellular Phone
Motorola Mobility RAZR V3 Logo
743 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
