Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL2260
Machine got to spin cycle and didn't spin....is full of water.....tried to turn off and then put on spin cycle...machine just hums but no action!!!.....checked wires/pip...all look ok....could drain be blocked?.....belt broken??/....ay ideas please
  • 782woods Apr 14, 2008
    Think the filter is blocked but cannot unscrew the inner cover. Front cover to filter unscrewed OK but cannot remove the inner filter cover - afraid we'll split the plastic if we try levering it off. Any suggestions for getting to the filter for cleaning?
  • goldenhazefs Aug 02, 2008
    machine washes but then the end light flashes, if I try to spin or drain machine just hums. help!!!
    recently replaced bushes that drive drum so machine pipes etc were all checked then.
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Posted on Jul 14, 2009
Hi all
thank you first of all for replying quickly. great site, Solved problem by first trying to work it out then tried what I could, things like drained the machine by hand and checked and cleaned the filter best I could, then still nt workng so looked around the net for a drain pump £ asked a few qustions at my local plumbing centre and so on and then met had this guy over who warned me that maybe the pump might need replacing and because I had a rough idea of price of pump his quote sounded reasonable so called him over and him ws able to cleaned the filter properly by litfting and tilting it and then removing existing pump cleaned the bit of wire that was blocking it cleaned it put it back and the whole thing took about 40 minutes and he charged me £45 which I felt was a lot better than the original quote!!! So very happy with outcome and my initial bit of investigation paid off well., thank you once again
Posted on Mar 29, 2008
SOURCE:
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Sep 30, 2014 | Bosch Washing Machines
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
Bosch maxx wfl2260 wont spin or drain
there will be a blockage in your "fluff" Filter cap. i could not get mine open so what i had to do was unplug the washing machine disconnected the filter from the waste and the blockage pipe and the electrics and found a bra wire i pulled it out with some long nosed pliers then the cap came off i cleared it all out connected it all back together and it worked good as new
Oct 11, 2009 | Bosch Washing Machines
Bosch Maxx Washing machine WFL2260
On most washers, this usually means, end of prog, and you should be able to remove washing.
plz rate my comments.
TYhankyou.
Jan 21, 2009 | Bosch Washing Machines
Fabric softener usage on quickwash
most likely normal operation .. try a normal or heavy cycle if it works there consider it normal operation
Nov 27, 2008 | Washing Machines
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
820 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
