Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
"AGS" problem. Has a new ignitor. Water flows freely.
I have a "Service" light and the "AGS" light is also lit. The skimmer/pump baskets and the filter are all clean. The pump flows freely and uniformly. I have replaced the Hot Surface Ignitor, although the ignitor's probe did not come with the kit so it is still the original. This heater was installed in 2002 and has had no repair issues until now.
  • aquablue1 Apr 27, 2010
    Thanks for the reply. The gas pressure is sufficient, and I have checked all other switches. I'll try cleaning the probe and see if this helps. Any other suggestions I could take with me to the job site?
    Regards,
    Jonathan
    I'll know when I get there!
  • 11,896 Answers
The probe should be thuroughly cleaned. That may be the problem. They have to be clean in order to maintain a certain temperature. If dirty, temps fall and pilot won't stay lit. Also check your gas valve to make sure spring is not weak and you get a good flow of gas. If you have done these steps and it is still happening, then you may want to consider doing some testing of any relays and power to the system
Posted on Apr 27, 2010
  • Nate Stansfield
    Nate Stansfield Apr 27, 2010
    Also take a look at the AGS (auto-gas shutdown) system
    The AGS and service light can come on for these reasons:
    No Flame at burners
    Low gas pressure
    Low Oscillating Pump Pressure
    Check these things:
    Filter is clean, Pipe line blockage, flame sensor, and ignition problem. (dirty probe)
    This system has 6 switch/components
    Pressure switch
    Hi-Limit Switch
    Air Flow Switch
    AGS
    Temp Sensor
    and 2 extra switches
  • Nate Stansfield
    The owners manual has some good diagrams if you need them.
    You can copy and paste this link in your internet address bar under a new tab
    http://discount-pool.com/product_info.ph...
No flow light is on. Have cleaned cell, back washed filter , cleaned out basket attached to pump and basket in skimmer box. Flow light is still on.
If you are referring to a salt system and your filter is clean. You will need to replace your flow sensor.
Dec 19, 2016 | Pool & Spa
How do i prime this swimming pool pump?
The normal procedure would be to unscrew the top of the inlet basket and fill that with water until it flow out down the inlet pipe, then replace the top cover. Make sure the skimmer box basket is clean, the pool water level is high, or put a fast running hose in the skimmer box to make sure the primed pump does not have to pull the water up from too low at the inlet.
If it will not pull the pool water in when started, then -
- there is a leak or blockage somewhere on the inlet side
- the pump impeller is damaged
- the filter is clogged too much and causing back pressure
- the pump power and pipe sizing are mismatched
Oct 08, 2014 | Pool & Spa
Lo flo pool power rp23
Clean your filter,...
... just a slight sensing of "Lower" water flow, may trigger the sensor to read not enough water flow. Also check your impeller, your skimmer baskets & the hair and lint pot basket at the pump.
If all those are confirmed as clean & clear - then you may have a faulty flow sensor.
Apr 24, 2014 | Pool & Spa
Pool pump surges water no steady flow
Check your water level, skimmers and weir gates, and the o-ring on the pump lid where the basket is. Air is getting in somewhere between the pool and the pump basket.
Mar 14, 2014 | Pool & Spa
Pool cleaner starts and then stops working
Check for water flow / water flow restrictions / and water flow blockages.
Many things create water flow reductions: Dirty filters, plugged impellers, packed with debris baskets - both skimmers and at pump, closed to partially closed valves, air suction leaks: worn shaft seal, worn orings at pump lid or pump volute body, low water level, stuck skimmer weir blade/gate in the up position & skimmer empties and air is sucked into the system which may cause the pump to lose prime. This a problem that goes un-noticed and is hard to detect even by some service technicians!
Jan 31, 2014 | Pool & Spa
No water flowing through pump
check top seal if ok check intake union see if loose or see if debris in impeller
Jun 16, 2012 | Pentair 15 Hp Superflo Swimming Pool Pump
I returned from vacation and the water level was adequate b/c it had just rained a lot. I think the water may have gotten low when we were gone. Now there is not enough pressure in the pump and the...
Any air getting into the suction line of the system can cause a low flow. If too much trans is in the skimmer basket or pump basket you cna get a low flow. If junk is in the pump impeller or the filter the flow can be low. Check each of these possible problem and you will likely resolve it. I hope this helps.
Aug 12, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I hooked up a new Polaris 280 pool cleaner to replace my Arneson Navigator and it doesn't move.
I would first take it out of the water and check for proper wheel RPM. If it is less than 28 RPM or you are getting no movement at all, it is going to be a problem with the power source. It is likely going to be that your booster pump is missing, malfunctioning, or is not installed properly on the pool cleaner. There are a few other things to check. Clean the skimmer, filter and pump basket, clearing any debris that restricts water flow. Check the hoses, connections and swivels for leaks. Try removing the blue restrictor disk from the UWF or if an adjustable gate valve is installed on the booster pump or cleaner line, open it completely so water can flow freely.
Jul 20, 2011 | Polaris VacSweep 280 Pool Cleaner with...
My zodiac pool filter is showing up with the light no flow on
Usually means the electronics in the pump has detected there is no flow through the pump. Check all inlets, clear skimmer baskets, and ensure the primer box (witht he removable see through lid near the pump itself) has water in it before starting the pump. If there is no output back into the pool, there is no actual water flow, and hence the filter will show the "no flow" light. If there is good flow through the system and the light is staying on, then probably just a problem with the light or flow sensing circuit.
Mar 19, 2011 | Pool & Spa
All DE is NOT getting sucked into the skimmer...why? Some went in and the rest is flowing out of the skimmer into the pool
You should always mix DE with water and make a slurry mixture. When you put dry de in the skimmer it will collect in the pump basket and slow or stop the flow of water being sucked through the pump. When that happens the de will just flow away from the throat of the skimmer just like you describe.
Apr 05, 2010 | Hayward Pool & Spa
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
224 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
