Question about Nokia N70 Cellular Phone
2nd camera N70 is not work - Nokia N70 Cellular Phone
My cell phone(nokia n70) is not diplay any operation. but the monitor is in order .what can ido?
Only 2 reason for blank lcd on N70,first lcd socket and the screen it self and 2nd Display IC (It need help from service center). to make sure Open your phone cashing and also all the screws.than release a LCD socket from VCB clean socket on VCB up with a thinner or alcohol. becarefull when cleaning lcd socket use a tooth brush and not much alcohol because it can make a flex on lcd.Congratulation if it work but if still blank it mean display IC need to change.
Jul 12, 2010 | Nokia N70 Cellular Phone
Camera problem
its a hardware failure. try to replace the back cover,camera switch is tapping with the back cover.If it didnt work try to clean up the camera module.
Apr 13, 2010 | Nokia N70 Cellular Phone
While opening n70 camara error is unexpected error
HI there, after turn on the phone don't open the camera.Just reset the phone from phone factory settings.After that restart the phone.When is completely ready for work then open the camera. I hope you naver face the problem.If you faced that problem again, then reinstall the phone software from net or nokia shop. Thanks.
Feb 25, 2010 | Nokia N70 Cellular Phone
My Nokia N70 Flash Light Is Not Working
my n70 mobile flash ligh not work in camera
Feb 09, 2010 | Nokia N70 Cellular Phone
My n70 do not boot
first of all try to check the adjustment of bettry
2nd check the chrger of the bettry..
3rd also note the lcd of bettry
May 29, 2009 | Nokia N70 Cellular Phone
Nokia N70 Camera Key
You need to go to servce center to avoid further damage
Apr 09, 2009 | Nokia N70 Cellular Phone
My nokia n70 back 2MP camera not workinh
Make a backup on your PC first,
Eject Memory Card from Phone
Format your Phone,
then Format memory Card through PC
some unnecessary library files in your memory card cause the camera not work
try this! :)
Mar 31, 2009 | Nokia N70 Cellular Phone
Nokia N70
Go to Setting-Network-Operator Selection. Keep it Automatic
Go to Setting-Call-Send my caller ID. Keep it Set by network
& check your line in use. Keep it in Line 1
Jul 06, 2008 | Nokia N70 Cellular Phone
N70 film slr
Yes. However, you won't be able to use all of the SB-400's capability; you'll be limited to what the N70 can do. But the new flash unit will do anything the old camera can handle.
Nov 05, 2007 | Cameras
Nokia N70
check your settings, try to OFF th Fixed Dialling. Go to the SETTINGS then SECURITY to PHONE and SIM then FIXED DIALLING. If it does'nt work try reformat your fon but the worst thing your file saved on your fon memory will be deleted.
Jul 05, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
