Question about Whirlpool ET8CHEXSQ Dryer
How to change a 3 wire to 4 wire on a dryer - Whirlpool ET8CHEXSQ Dryer
  • ElectricMan
    ElectricMan May 11, 2010
    In order to do this you need to run a new wire from your panel box, the wire is called 10/3 with ground. that allows for a separate ground wire for your dryer, whereas a cable with only three wires has no separate ground. If this is something you want to do, send a comment back, I can walk you through it.
  • 8,197 Answers
Under the new Codes...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the two.
Hope this helps,....if you need more details, please follow-up.
Posted on Apr 27, 2010
How to ground a MDE6700AYW dryer after changing to a 3 prong cord
Hi fievelsgal21...
Go to the following webpage and it will show you what and where to connect the ground wire when converting from 3 to 4 wire or 4 to 3 wire.
Please rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 28, 2012 | Maytag Neptune MDE6700A Electric Dryer
I WANT TO CHANGE A CORD FROM A 4 WIRE SET UP TO A 3 WIRE SET UP WHAT POST GET THE JUMPER
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 30, 2011 | Dryers
I need to change the power cord from a 3 wire to a 4 wire on a admiral mega 22 plus dryer
heatman101
Aug 28, 2011 | Dryers
Changing from 3 to 4 prong. there is already a ground wire, not a bonding strap. what do i do with the ground on the new 4 prong cord?
heatman101
Apr 02, 2011 | Whirlpool LER5636P Electric Dryer
Need to change out the wall plug to fit the dryer plug. The dryer is a 4 prong and to wall is a 3 prong.
heatman101
Mar 18, 2011 | Dryers
I am changing from a 3 wire plug to a 4 wire plug. In what order do I connect the 4 wire to the back of the dryer?
heatman101
Sep 19, 2010 | Maytag Dryers
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
heatman101
Sep 15, 2010 | Kenmore Dryers
TEDS680EQ2 estate dryer. I need directions on how to change a 4 prong plug to a 3 prong
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 25, 2010 | Estate TEDX640JQ Electric Dryer
My dryer has a 4 wire i need to change to 3 wire cord
Here is a tip that explains the hookup in detail.
You can easily change that dryer fron 4 wire to 3 wire.
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 20, 2010 | Dryers
Whirlpool ET8CHEXSQ Dryer Logo
243 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
