Behringer Xenyx 1832 FX mixer - re the GAIN knob controlling the input level for MIC and LINE inputs - this function appears not to work correctly as the knob has to be turned to the right, ie it has to be on Full Gain to get any signal from mics to the powered speakers. Anything less and the mics do not work. Also therefore when at full gain, it sends a distorted signal to powered speakers. Thanks!!
  • 2 more comments
  • GEOTRONIC Jun 20, 2008
    Yes I have a same problem with Behringer Xenyx 1002FX model. Also during the mic input alignment gain oes to very high suddnly. This situation was highly dangerous for Loudspeaker. This is a design fault of Behringer.
    I have another problem. After warm up 10-15 min. mixer temperature reach to 53 celcius degrees at the bottom side. And I occurs at Mic Inputs2 a pop and click noise with randomize. If I reduce to MİC 2 Level potentiometers ( Not trim potentiometer) problem dissaperas normally. For this reason I bring to seller my mixer for change.
    I am waiting the result.
    Behringer is a very famous brand, but I couldn't understand why it has a abnormal problem of new series mixer.
    EMREM from Turkey-Istanbul
    Electronic Enginer
  • Gazzor Nov 30, 2008
    Same problem with my UB2442FX PRO. Low input volume until the last little twist of the trim pot and POW, all the volume you would have expected to get as the pot was rotated, only in the last two degrees of turn.
    It this a design issue, or is my board broken?
  • Anonymous May 01, 2009
    Yes I have same problem with the XENYX 1204FX gain nob on the Mic input need turn to maximum
  • Anonymous Mar 25, 2014
    Same though headphones as well as speakers
I had exactly the same problem with XENYX 1002FX but the warranty covers this, I had my unit replaced with a new one which does not have the fault.
Posted on Apr 03, 2009
The clip light means your input signal is too high and distorting. Turn down the attenuator(input) knob until it goes out, use the channel volume for level. It should have a knob for the names of the effect selection.
Mar 22, 2014 | Behringer XENYX 2442FX Mixer
Xenyx 502usb not picking up mic
It sounds like you have a condenser mic hooked up to the XLR input. Phantom is not available on the other inputs, just the XLR.
Check page 8 of the manual.
Jan 05, 2014 | Behringer XENYX 502 5-Input 2-Bus Analog...
Xenyx 502
You can only do this with a LINE OUT of your amplifier, or HEADPHONE out, as these are line level outputs and will not hurt the inputs of your mixer. Otherwise the signal going to the mixer will be too hot and ruin it. For a Marshall amp,I would prefer to mic it anyway, and run the mic cable to the mixer.
Jun 08, 2013 | Behringer XENYX 502 Premium 5-Input 2-Bus...
I cant get sound from fx send to my computer
Open the volume mixer on the pc and make sure the mic port is on. When you find it, click on the "advance" tab and there will be a check box allowing you to add 4db to the volume of the mic. Also, make sure it is plugged into the line in or mic input on pc.
Mar 16, 2013 | Behringer XENYX 802 Mixer
Have a Behringer 1202 Xenyx FX, balanced cable into a new windows 7 PC and keep getting hiss. When I raise the gain, mic or master volume the hiss is more awful. my internet broadcasts sound awful. what am...
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Jul 10, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
I cant figure out how to connect my xenyx 1832 fx to my desk top computer
alcuni canali non funzionano metto il microfono e non va lo metto in un altro canale funziona come mai? salve e grazie gioago 1
Mar 28, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How do i set a behringa 1832 fx mixer
I have a behringer 1832fx mixer and have the manual that illustrates how to set up for a band and/or other instruments etc! is this is what your asking for?
regards Col
Jul 07, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Dec 03, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
831 people viewed this question
