Question about Dewalt Saws
I cannot work out how to turn the mitre table when using the chop saw to cut a 45 degree angle. the knob at the from has a press down centre middle but doesnt seem to want to do anything. model using is a d27105
  • 623 Answers
Sometimes the knob has to be unscrewed to release it so it can be pushed down or move the table.
Posted on Apr 27, 2010
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
How to mitre corners
using a set square , The angle if 45 degrees is machined into the handle draw a line at 45 degrees across the surface you wish to mitre cut
clamp a piece of timber along that line and use it as a guide to cut with the circular saw
Apr 27, 2016 | Saws
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Does the Draper 76211 chop saw cut 90 degree mitres
pambrook04-
Yes, it will cut 90 degrees. Other angles are possible as well.
Hope this helps.
Regards,
DIYpro
Apr 30, 2011 | Garden
I have an outside corner cut with a 45 degree slant and cannot figure out what my angle should be to get the right outside miter cut
You can solve this with geometry, but it will take forever and your answer will only be approximate (due partly to the limits of accuracy of the scales on your saw). If you are using a table saw, use scraps of wood and trial and error. It takes a while, but you can get a perfect result. If you are using a miter saw, then support your work from underneath at the angle to match your situation, and simply cut at 45 degrees.
Aug 31, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How do you tip the saw table to cut on an angle
Hi, usually there is a wheel or knob at the back side of the saw table , with a gage that will tip the blade for angle cuts
What make a model is your saw? I will search for details.
Please Vote !!
May 30, 2010 | Saws
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Looking for help scouts have a carpentry merit badge from the 50s they talk about using a BEVEl and a Miter tools can you help
The bevel is an angle fiding tool. it consists of a wooden section about 4" long with a swivel bolt at one end connected to a slotted metal blade (similar to a 1 foot steel ruler). The bolt has a wing nut and bolt to allow loosenig to allow the blade to rotate and slide to the required angle where it is locked into position using the wing nut.
The mitre is a wooden block with slots cut into it at pre determined angles. ie 45 degrees. When cutting a mitre joint the wood is placed against the block and the saw follows the line of the slot cutting the 45 degree angle.
Hope this makes sense and good luck
Feb 18, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
Outside corner one side 30 down [ crown moulding ]
If the corner is to be 90 degrees than all you need do is set the compound angle on your chop saw at 15 degrees to get the 30 degree down side. If you cut only one side the thickness will be different at the joint so you have to spit the angle. Boy now you got me going. Tomorrow I'm going to be trying this cut in the shop myself. Good luck.
Apr 05, 2009 | Saws
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
Saws Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
