Question about Kenmore 59946 Kitchen Hood
Downdraft will not stay elevated.
Every time I hit the button to raise the downdraft it goes up then immediately goes back down. It used to do this sporadically; I would have to hit the button several times, or physically hold up the hood when it raised in order to get it to stay up. Now it never stays up.
  • 1 more comment
  • Anonymous May 07, 2008
    SAME problem..now it NEVER comes up even though you hear the motor trying to do something.
  • chronophage Jun 11, 2008
    Our downdraft will not come up at all. I can hear the motor running but it won't elevate. It will work for a few weeks and then suddenly repeat the same behavior then start working again without specific intervention.
  • Anonymous Dec 26, 2008
    i have the exact same problem with my jenn-air downdraft hood. tonight however it has gotten worse. if anyone finds a solution, please post it.
    Problem Solver:
  • 14 Answers
    New Friend:
On my kenmore elite downdraft model number 233.59946090 the same thing was happening to me. my unit would go up and down automatically, sometimes 5 or 6 times in a row.
the problem was the top button that activates the up and down motion was too close to the switch underneath it. the fix is to remove the 2 screws on the side with the vent speed control. under that you will see 2 more screws that hold the entire switch assembly on. loosen these screws and move down, this will lower the switch so it is not hitting the underside of the button to hard and mistakenly cycling the switch on and off.
good luck
Posted on Oct 29, 2012
SOURCE:
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
DCS 36" Downdraft will not elevate
The few I have serviced have all been micro switch related even the factory cannot help us in the field most models have two screens with a switch behind both brlow are either 2 or 3 micro switches my technical guess one is bad or out of adjustment
Feb 08, 2014 | DCS Dd30ss 30" Downdraft Ventilation 600...
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
I have a Broan 2736 Eclipse downdraft blower system. When I push the button the downdraft rises but then immediately goes back down
Gail was spot on. That worked for me until the unit would go up and/or down on its own. The problem was traced to the double microswitch called the 'Lower Switch Bracket Assembly' ($24. thru Lowes ). To replace these switches is not for the faint of heart as it is deep within the assembly. A good weekend mechanic can look at the exploded parts diagram and see what / where. Found grease residue on- and slightly within- the microswitchs due to Broan not properly design shielding and protecting these critical switches from grease. Did not find any ghosts, however.
Nov 08, 2010 | Broan-NuTone 273603 Kitchen Hood
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Downdraft doesn't alway go down and up.
I have the same problem. Seems to be pretty common that the motor that raises the unit goes bad. Ours is 2 1/2 years old and has not seen that much use....that motor should not have failed that soon...and this is a high end product!!! I have been quoted $289 for a replacement motor and $150 for labor!! So, $450 bucks....gads. The unit, new, cost about $900, as I recall.
May 08, 2007 | Thermador UCV36ASS Kitchen Hood
Kenmore 59946 Kitchen Hood Logo
1,610 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
