Bugaboo Cameleon Jogger Logo
Posted on Apr 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Handle one siad keeps colapsing so unable to go down stairs. when going down stairs the handle oneside keeps clicking out of place and down.
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Apr 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
16038
Points
57
You need to have your chassis repaired by www.buggypitstop.co.uk we repair and service bugaboos
Stephen Faulkner
Level 2:
Guru:
  • Expert 541 Answers
  • Posted on Nov 02, 2010
Stephen Faulkner
Expert
Level 2:
Guru:
Answers
541
Questions
Helped
237749
Points
983
You need to clarify your question. Not sure if you mean the handle extension lock or the handle release.
  • Stephen Faulkner
    Stephen Faulkner Nov 03, 2010
    You have a problem with your locking mechanism I've posted my How to repair many time on this site but you can email me on [email protected] and I'll send you a copy as a word doc compete with pictures. But first try LUBRICATING On the inside of the handles where the handle joins the plastic hub there's a slot in the plastic. In the slot you'll see a wire rod. Spray it with silicon lubricant till it starts to drip out the hub than work the release button repeatedly then wipe down with a rag. Bugaboo supply a small can of silicon spray or you can buy a better value full size can from any hardware store.
1helpful
1helpful
Wireless router
well the only place you can check is if you right click on your my computers on the desktop, click on properties, go to device maniger and there you will see all the hardware in the pc.
What's your problem?My back seat for my 06 honda odyssey is stuck in the colapsed position. It will fold down into the floor, but when you take it out and lock it in place, the back of the seat wo
Check that the seat belt has got jammed & this is what can be stopping the seat's staying up as they have something stopping the seats locking into place. Best Wishes, Malcolm Campbell.
I keep searching for an answer and nothing seems to understand my issue. It's not that the handle wont go back into postition.. the extended peice of the handle used for specific areas such as stairs ;...
To reattach the wand and handle to the cleaner to resume floor vacuuming, just place the handle back onto the main cleaner body. The wand will then retract automatically down inside the hose - simply guide it back down through the handle until you hear an audible 'click'.
If this is not the problem you're referring to, I'd encourage you to contact us directly so we can determine exactly what issue you're experiencing, and provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
2helpful
When bumping up stairs handle bar extends, and feels loose (handle bar is very wobbley)
The Bugaboo is not the ideal stroller for bumping up and down stairs, The reason being it's core design. Most stroller handles have two or more mounting points to the frame but most strollers have baby facing forward and facing the big bad world and not Mummy. The Bugaboo is very clever, the handle can be locked ether way and the seat face either way but the handle has only one point where it attaches to the frame and that point has to rotate and lock. To give you an idea of the forces involved a crow bar the length of the Bugaboo handle can pull six inch nails out of hard wood!
Unfortunately Bugaboo have not used the best material solutions in this critical handle lock. They use a plastic disk to move aluminum locking pins and they fail if you bump down to many stairs. This happened to our Bugaboo in New Zealand. I repaired ours and now I help others by making or sourcing the better quality parts to repair them. I use aluminum for the disk and stainless steel for the pins.
If you are lucky another to have a Bugaboo less then two years old and still have proof of purchase documents Bugaboo will replace the frame for you. If it's older you can buy a new frame for around $400 but this will also increase you resale value by around $200 when you sell it. Lastly you can repair it for around $100 a side depending on parts required, Click on my name and you'll find many posts on how to repair both the Handle lock and the Handle extension lever or wing-nut. macnutz_23.jpg
18helpful
2answers
How to attached stair cleaning attachment
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
9helpful
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
2answers
I have a dyson dc 07 how on earth do i connect the flexible hose for cleasning the the stairs to the machine
Hi its Darran at Dyson.
I am not clear from your question as to whether you have purchased a replacement hose and need to know how to fit it or you are asking how you use the hose to vacuum?
If you are trying to fit a new hose, with the old one removed, simply line up the large plastic cuff on the base of the hose (this is the one with the cable tidy) and push it downwards into the slot at the base of the main body until it clicks into place. You can then insert the wand handle back in and store it on the machine.
If you would like to know how to to use the wand/hose, simply press the wand catch on the front of the wand handle just above the main carrying handle and pull it upwards. You can then splide the hose to the bottom of the metal pipe and press the button on the hose cuff to release the wand handle. The tools fit directly onto the hose cuff for vacuuming the car, your stairs or upholstery.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Icoo pico 3
press the button on the handle (that colapses the handle) then sharply push the handle down and you should find that it folds down :)
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
