Question about Fisher and Paykel GWL11 Top Load Washer
The cycle stalls out when it gets to the rinse cycle. When I unloaded the soaking clothes and bailed out the drum, I was able to get it to spin, but it smelled "hot" like maybe rubber or metal getting hot. Also I noticed the drum look like it is riding low inside the casing. There are no service techs in my area...any help is welcome.
  • sonic boom electronics
    sonic boom electronics May 11, 2010
    i would say it needs a new water pump there is a small plastic cover at the front bottom of machine take it off and take of the pump and replace
Redistribute the clothes and restart the rinse cycle. this may solve your problem.
Posted on May 02, 2010
Why are the clothes still soaking wet after a wash cycle.
Hose could be clogged up.Take hose off and see,maybe run with hose off for a sec.
May 22, 2015 | Washing Machines
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Machine stopping prior to rinse cycle, not draining.
Hi Jackie, more than likely you have a timer control failure. It's an easy fix if you have money and can afford a repair man to fix the problem. It's a lot better plan if you have friends with a few skills. Just need to enter model number of your washer on ebay and ask for a replacement timer. It is behind the cycle control knob on your washer. Invite a couple friends over for a cookout and repair your washer. Don't have any friends? If close enough will be glad to help. Simple fix, have fun, good experience. Stan
Apr 02, 2017 | Kenmore Whirlpool Duet Sport Washer Door...
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Clothes are still soaked after spin cycle
What is the model number of your unit?
Nov 18, 2012 | Estate Washing Machines
Washing machine will not go into the spin cycle - it stalls at the end of the wash cycle leaving the clothes soaking in a tub full of water i tried to restart at the rinse cycle and it stalls after the...
This is usually caused by a bad lid switch. Whirlpools are known for lid switch issues. If the lid switch is not telling it that the lid is closed, it will not spin. Look where the lid switch is and press on the lid directly above it -- it may start. This will prove it. You can find an exploded view (and get the part) at www.appliancepartspros.com
Feb 14, 2011 | Whirlpool Washing Machines
Even after doing the spin only cycle, my clothes
Is drum spinning on spin, check belt tension if not. if this is ok then it could be problem with motor brushes, or if it is induction motor it could be a capasitor
Feb 08, 2010 | Washing Machines
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
95 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
