Question about Toshiba TLP S30 Multimedia Projector
When I project, the display on the wall is green, can't figure out why. Is it the INPUT into the projector?
I have lcd projector but problem to connect dell vostro 1510 only not show laptop. only show lcd projector but without show laptop. i need both laptop show and lcd projector how explain me.thank
Posted on Jul 04, 2010
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
Y, pb, pr no signal
you need to be sure the computer resolution is 1024 x 768 be sure the projector is set to rgb or vga input signal type.
Dec 21, 2012 | Sharp Notevision Pg-m10s Dlp Projector...
Picture not straight when projected onto a wall how do i fix this ? projector novice Many Thanks
There is a setting called keystone correction. Use this to correct the projection.
Go through the menu and you will find how to use keystone correction.
If you can't figure it out, keep the projector further away from the wall, on a higher stand. Reduce horizontal angle.
Sep 24, 2011 | Office Equipment & Supplies
When hooking up r,g,b via component or vga input only the green channel displays.
reset the settings to factory default, then make sure if you are using component that the input selected is component and not vga. is the source rgb-yb?
Oct 03, 2009 | Christie Vivid Green Multimedia Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Green haze projected on wall
the Lcd panels were broken, you need a new one,USD120
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Oct 26, 2008 | Sanyo LAMP Projector Lamp FOR...
Projector problem
If replacing the lamp did not fix the problem, I would suggest to check the cables that bring the video from a computer or any other device that you are connecting to the projector.
Also try to hook up a DVD player using the video output from the DVD to the video input on your projector.
Good Luck.
Feb 05, 2008 | Televison & Video
Lamp Cover will not close fully
Hi there
Your lamp is not properly inserted.
The lamp door should close easily if your lamp is in correct.
If teh lamp door is not closed properly then the mashine will keep on shutting down.
Dec 13, 2007 | Sony VPL-CS7 Multimedia Projector
Getting image to project
You are going to have to read the manual, and operate the projector as you read each section
Oct 16, 2007 | Sony VPL CS2 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
216 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
