Question about Dell Inspiron 1525 Notebook
Battery loses charge, despite power cord always plugged in. Unit has a new rechargeable battery
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 349 Answers
This is very common on laptops. First take the charger to a shop to be checked. If bad, replace it. If good the problem is probably the connector where it plugs into the laptop. Unless you are very mechanicly inclined this will require a trip to the shop.
Posted on Apr 27, 2010
How to recharge superex jumpstart/compressor
Plug in the cord with the switch off. If the battery is still good in the unit then it will take a full day to charge. If you charge it for a full day and you still have nothing the battery is bad. If this is a new unit, check to see if it is under warranty.
Sep 06, 2014 | Superex Canada Ltd Emergency Jumpstart...
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Rechargeable battery cannot be charged despite continous plug in of AC cord of charger
Battery is probably dead. Will need to purchase new one, not repairable. When replacing, do not buy "new" battery that has been sitting around on a shelf for several years. Will have much shorter life. Insist on battery that has been made within the last year, maybe 18 months at most. Expect to pay $50 to $125. To increase battery life, try not the let them fully discharge when using. Most recommendations are keeping them above 10% charge.
Dec 02, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Dell Inspiron 1525 Notebook Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
