Question about Canon PIXMA iP3000 InkJet Photo Printer
My black ink on my Cannon Prixma 3000 is blurred and missing in areas. I have tried regular cleaning, I have tried deep cleaning. I have tried bottom plated cleaning. I have put in new cartridges but I still have the blurred missing black printing. If I print on fine with all colors even if it is just text, it's not too bad but that uses a lot of ink when I don' t need too. Is there anything I can do short of replacing the head or buying a new printer.
  • 4,041 Answers
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
My canon c3480 not printing cyan, how can i fix it this problem
First confirm that the cyan ink cart actually has ink in it.
If you do have ink, run a "head cleaning" In the printer driver, there should be a "Maintenance" tab, and in that should be a "Cleaning" button. You may also have a "Deep Cleaning" capability. Try regular cleaning first, and see if that clears the probem.
Aug 17, 2016 | Canon ImageRunner C3480 Color Copier
The black ink in my mp258 canon printer is blured how can i fix it
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Jan 16, 2013 | Canon MP250
My Cannon Mx870 is missing parts of the picture
FIRST: I THINK THE TEMP. AROUND UR CANNON PRINTER MUST BE COLD , down temp. TRY TO KEEP UR CANNON PRINTER WARM (not more the n room temp, while summers)
2ND : ur cannon printer must having colorfull ink rather then black and white which get JAM fastly in cold days
CHANGE UR INK !!!!!!
Jan 05, 2012 | Canon PIXMA MX870 Wireless Office...
The 3ebk nozzle check shows problems and prinitng is blurred
First of all you take out your cartridge form printer and try to clean nozzle from tissue paper then insert the cartridge in your printer then take a print out. If it is still not working then you have change your cartridge.
Regards
Ashly
Feb 04, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My printer does not print black ink even i try to do a deep clean. PLEASE HELP ME
You may need a new black ink cartridge. Most printers have seperate ink cartridges for color and black you can get cheap ink from ebay.com just type in you printer model number and make in the search. example "cannon 4200 ink" then search
Jul 01, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
Inconsistent print quality - from black to blurred gray
please don't say that
kodak is very good and your problem is VERY COMMON
If you call 1.800.421.6699 and select option 01 for prints missing black or color in, Kodak will send you a replacement printhead kit for free.
by the way, I don't work for kodak
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blurred lines
hi, try a new ink catridge and after that no change, the head needs to be cleaned.
Jun 28, 2008 | Cannon i70 Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Black Smudges of the First Copy. Canon pixma ip 3000.
try cleaning all the runners that the paper uses on the printer. Clean the dabbing pads inside the printer too.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
210 people viewed this question
old marine
old marine
