Question about Tomtom XL 330 Car GPS Receiver
When i turn my tomtom one on it just shows a flashing cross and wont start! what do i do?! i've tried the reset button but that just turns it off and when i turn it on again th same problem occurs, please help!
    Scholar:
  • 150 Answers
That means your operating system is missing important files, and is unable to start up. Contact Tomtom support and they can walk you through installing the operating system through TomTom HOME.
Please Rate, thanks!
Posted on Feb 27, 2009
SOURCE:
I have a car tomtom GPS and it will not turn on.it came on early this morning went off and wont cut back on.i've had it since May
What model of tomtom is it, can tell you how to do a flash reset then, it will not lose your data
Dec 22, 2014 | Tomtom GPS
My tomtom wont power up
You may want to try a reset by pressing the reset button on the bottom of the GPS with the end of a paper clip.
If the reset does not work, try using the "Clear Flash" tool.
http://www.tomtom.com/6178
Also you may want to contact TomTom Customer Support for assistance.
http://us.support.tomtom.com/app/home/?Lid=4&locale=en_US
Nov 17, 2011 | Tomtom ONE GPS Receiver
Gps shows a blue screen with a picture of the tom tom with a red X on the screen flashing. what do i need to do?
Assuming that your Tomtom is a Go910 or similar:
The normal solution for this problem is to reset your device.
This is done by pressing the reset button (usually found at the rear of the device) for a at least 15 seconds.
Once you have done this, turn your machine on and the red cross should have gone.
Feb 11, 2011 | Tomtom GPS
Tom tom go 910 red cross flashing wont re set
Well i am writing this wile I am trying this out...
I have a TomTom Go 910 that has a RED CROSS FLASHING on the bottom corner, what I have found is that if you have backed up your TomTom Go i maybe able to reset the TomTom Go on my computer but if you havent you may have to find on try finding one on google but i have a TomTom Go 910 you can download the 910 on http://rapiddigger.com/download/backup-go-910-rar-9110176/.
after you found the back-up you can connect your TomTom Go to your computer using the USB provided from your TomTom Go, replace the doggie file with the new one, then this should change it back to the FIRST update given...
(WARNING >> PLEASE scan the file befor you put it in your TomTom Go it might contain a very very evil virus<< WARNING)
Jul 12, 2010 | Tomtom GO 910 GPS Receiver
Tomtom one wont respond flashing red cross
have you removed any files from it when you had it hooked to the computer. first step I would try reset it with the button in the pin hole
Dec 27, 2008 | Tomtom ONE GPS Receiver
730T - tomtom home hangs when checking for updates - mac
Hi - have had the same problem - if you look on the tomtom website and support they have a list and one is flashing red cross. You need to follow the steps to format the tomtom. I did this and it worked and it included the update. i havent reconnected since i have it working now. I think its a software problem with HOME. Make sure you do a back up on home and make sure you follow step by step. close HOME before you start to reformat and also in the preferences turn off the automatically connect to home when you plug into your computer or it keeps flashing up on the screen to correct. the only solution is to format it. i bought mine two days ago and the first one stuffed up so took it back for a replacement. this one worked when i turned it on but turned out the flashing cross appeared when connected to computer (i have a mac). good luck
Dec 20, 2008 | Tomtom GO 730 Car GPS Receiver
Showing "X" and wont go to home menu
If your device only shows a cross after you turn it on, the TomTom application is not installed or cannot be found.
Visit this webpage for instructions on how to fix your GPS .
TomTom ONE support-- Device shows a flashing cross when turned on
Glad to have helped you !
Jun 01, 2008 | Tomtom ONE GPS Receiver
TomTom ONE has flashing "X" and picture of TomTom
I found this.
Question: Device shows a flashing cross when turned on.
Answer:
To solve this, follow the steps below.
Manually remove the TomTom application:
Reset your device.
Connect your device to your computer.
Turn on your device by pressing the power button for 5 seconds.
Do one of the following:
Windows: Click Start > My Computer and then double-click the Removable Disk for your TomTom device.
Macintosh: Double-click the desktop icon for your TomTom device.
Delete all files except the following:
Do not delete any of the folders!
Do not delete the files antitheftw.bmp, lowbatteryw.bmp and splashw.bmp (if present)!
Reinstall the TomTom application:
Start TomTom HOME
Select an option:
I previously updated my device on this computer
I never updated my device on this computer
Click Done and then click Device > Disconnect Device.
Your device should now start up again. If it hasn't started up after 10 seconds, press the On/off button.
Nov 09, 2007 | Tomtom ONE GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
Tomtom XL 330 Car GPS Receiver Logo
349 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
