I have a 50" plasma Panasonic TH-50PZ700U that has a black line about 2" in width that goes from the bottom of the screen to the center of the screen. Everything else works fine. Please help.
  • 3 more comments
  • farmers167 Apr 27, 2010
    I replaced board C2 with a new one but still have the same issue. You can view a pic here...http://london.kijiji.ca/c-ViewAdLargeIma...
    what else could I try?
    I replaced board c2 with a new one. I still have the same issue. Here's a pic.http://london.kijiji.ca/c-ViewAdLargeIma...
    I have replaced the c2 board with a new one but still have the same issue... here;s a pichttp://london.kijiji.ca/c-ViewAdLargeIma...
    any other ideas would be much appreciated.
    thanks.
    Tried tapping on the screen and no change.
    yes i do
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to check the X and Y sustain buffer boards. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged capacitors on these boards and replace whichever has gone bad. If still the issue is not resolved, then please check the power supply board. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment further assistance.
Thanks
Rylee
Posted on Apr 27, 2010
  • 4,889 Answers
You have bad sustain boards on your tv. Most panasonic tvs have two sustain board X-sus (also performs z-sus functions) and Y-sus. These boards have to be physically tested using a multimeter that can measure capacitance. In rear cases this is also caused by a faulty panel. Tap on the screen(Gently and see if the stuck pixels in the tapped area are released and let me know.
Sai.
  • eagle338
    eagle338 Apr 27, 2010
    Good that you have posted the image. From the looks of it , its a bit more advanced problem which points to the buffer boards. Do you know how to use a multimeter?
  • eagle338
    Cool. Do you have one that can measure capacitance? If you do then discharge the caps on the buffer board and test them one by one and see if any of them reads "OL". If you need additional help with locating the buffer then let me know.
    Sai.
  • 19,396 Answers
Hi.
If the picture is more or less like this:
I have a 50
Then you have to replace the low Data drive (Cboard on Pana service manual). The main controller board and lower data out must be tested before replacing buffer.
Here the boards layout. The problem is usually one of the boards named C1, C2 , and C3:
  • Ginko
    Ginko Apr 27, 2010
    If you replaced c2 you need to test sc and d board. Also test again the newly replaced C2. driver chip is very sensitive and can be damaged when the board is touched.
    After negative rating the question will be passed to a different expert.
    Goodbye and good luck.
    Ginko.
  • Ginko
    Ginko Apr 27, 2010
    I have checked your picture. That is a faulty C board.
    I am out of this problem, the system will re-locate you to a different expert.
    Bye.
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have Panasonic TH-50PZ700U and the viewing screen is small and never goes back to full screen. Tried checking all options and none make screen go back to full
Are you sure you have tried the aspect button, usually the one top left on remote, press it and select ( with arrow buttons from auto 14.9 16.9 4.3 zoom 1 2 3 etc this will fill out screen,
pete
Nov 15, 2010 | Panasonic (TH-50PZ700U) Television
Screen has a long black line down the center.
I also have the TH42PZ80U and I just had the certified Panasonic repair person out. The problem is this is the THIRD time in two years. Any quesses on what's wrong? It's a bad panel, again. That's right, three bad panels in the two years I've own this tv. I am now one month out of the panel warranty and guess how much the bid is to replace the panel. $1542! I only paid $1300 for it. Panasonic better make this right. I think a whole new tv is in order just for my trouble. After reading about so many of us having this problem, we are probably getting close to a class action law suit.
Apr 29, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Black line about 2" in width from the bottom of the screen to the center of the screen.
No that doesn't look like it. I will see if I have a service manual and post back.
Feb 23, 2010 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Picture does not fit screen
make sure you cable set top box is set to proper aspect ratio should be 1080i
Mar 23, 2009 | Panasonic (TH-50PZ700U) Television
Black bold line on panasonic plasma screen
Hey,
Your problem goes outside of my expertice, I would recommend you ask http://www.fixya.com/users/slinteriors Slinteriors for help, send him the problem, hes one of the best TV experts we have on this website I'm sure he can solve your problem
Thanks,
Ekse
Aug 29, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Plasma display fault
nhjchabghchtybahbbyug
Mar 12, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
