Hi - I accidentally used gel liquid in my frontloader and the washer overflowed with water. The buzzer then went off and an error message on the screen said "waterproof system activated"..how do I clear the program and stop the buzzer?
  • 129 Answers
Good day.
Water may have been able to disrupt the units system.
Leave your unit to dry for 2 days. The system will just reset itself then.
chris
Posted on Mar 24, 2008
SOURCE:
What do we when we replaced the pump on a frontload washer, LG, but still get an error message OE?
The DE Code indicates a Drain Error. This means that the washer thinks the water has not drained out of the tub within 10 minutes, which is an eternity for the washer. Since you have indicated that there is no obstruction in the hoses, and filter, and you have replaced the pump, then the only other parts that could be at fault would be the water level sensor, or the main circuit board. Replace in that order.
Aug 16, 2014 | LG Washing Machines
Maytag neptune frontloading washer overflow
If you cannot clear the line, you will need to replace it. Here is the line to order.
Nov 22, 2012 | Washing Machines
Hi I keep getting an error message "F27" on my
F27 OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Aug 31, 2011 | Bosch Axxis WFL 2060 Front Load Washer
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
Check
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
When washer was off it filled up with water and overflowed will a water inlet valve fix this. this is a whilpool washer frontload ghw9100lq1
Yes, it should. The only way water can enter a washer when off, is through a stuck inlet valve, or by siphoning water from a drain hose installed too deeply in the stand pipe. If your machine had enough water coming in to overflow, that definitely sounds like a bad inlet valve.
Apr 21, 2009 | Whirlpool Washing Machines
Dish washer will open and let the gel pack out.
The gel packs are not supposed to go inside the dispensor. It is for powders & liquids. The gel packs & blocks just go into the dishwasher, per directions on package. They either go into the bottom or with the silverware.
Mar 05, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Bleach & Softner not emptying
What "form" are you using? liquid, gel, powder? try using a different type and lean towards the more liquid forms if your washer can handle them, ie move from powder to gel or liquid, and from gel to liquid. Hope this helps.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Powder or Liquid
. HE detergent is a must for these machines first and foremost. as a genral rule liquid detergent breaks down better in cold water, so performs better in washers(cold water rinses). powder breaks down better in hot water which is why its reccomneded for d/w's.that being said i dont really mind which is used where so long as your not experiencing cleanig problems, at that point its when i reccomend using the appropriateone. whirlpool has now reccomneded a product called AFFRESH, tablets that can be used to clean out you frontloading machine incase of residual build op and/or odors.
Feb 28, 2008 | Whirlpool WFW8300SW
Washing Machines Logo
612 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
