Question about Mk Diamond MK - 170 Wet Cutting Tile Saw
Looking for shaft lock to change the blade on MK 170 wet saw
Looking for shaft lock to change the blade MK 171 wet saw??????
  • 843 Answers
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Posted on Apr 27, 2010
While checking the intake tube the power cord got on the wrong side of the cord so when I turned the saw on it cut the power cord. Can I get that replaced?
Yes, it will require that you "crack" the case, but it isn't that difficult to do. Suggest wire ties so that you don't have to do the replacement very often.
Jul 15, 2011 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
MK water saw - water goes every where but on the blade!
When you say you turn the pressure up, I presume you mean you are opening the suction on the side of the pump.
On the saw which I have used in the past it is difficult to aim the warter spray. I opted for more water (open the suction on the pump) and let it go. most of it went onto the saw blade - some went onto the tile, some on me and some on the wall --- put a piece of cardboard or something behind your saw to help contain the overspray.
Sep 07, 2009 | Mk Diamond MK - 170 Wet Cutting Tile Saw
The saw in not pumping water
I have came across to possible solutions with other tile saws in the past. One is that your pump could have picked up a small piece of tile or sedement from the basin and got stuck in the water port where it comes out on to the blade. The first thing I would try is to disconnect the hose frome the blade shroud while saw is off. **** on the end of the hose until you get water. Sometimes the line needs to be primed and filled with water. Once you get water you can turn the pump or saw on while disconnected to see if water flows. Keep loose hoses away from blade though! If nothing then try the blocked port. Good luck
Dec 03, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Oct 29, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Mk Diamond MK - 170 Wet Cutting Tile Saw Logo
541 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
