Question about Dell Inspiron 1525 Notebook
Battery doesn't charge, despite power cord always in use.
    Scholar:
  • 62 Answers
Laptop batteries generally last a couple of years before giving up.Either the battery is faulty, or the charging circuit in the system board is bad. The easiest test is to swap batteries with another laptop... easy that is if you have another laptop. Maybe a local shop could loan you a battery for the test or they could test your battery? You could purchase another battery; that would certainly be cheaper than replacing the system board.
Posted on Apr 28, 2010
Testimonial: "I appreciate your assistance. I have a new Lithium Ion battery. Just ordered a new power cord... if that doesn't make a difference, I'll take it in."
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Acer extensa 4620 z will not power on have a new ac adapter and power cord . i can charge battery and charge battery light comes on but push power button and nothing
Try the following, one at a time.
- Remove battery then connect power cord, then power on
- Remove the memory modules then power on
- Remove the other optical drives, then power on
- Remove other components, then power on.
This process is to illiminate the faulty component. It is possible that one component is faulty and is causing shortage that's why your laptop won't power.
If this doesn't work then you need to remove the internal components like hdd.
Hope it helps.
May 08, 2011 | Acer Computers & Internet
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
My toshiba m645-s4047 does not start despite the fact that the battery is charging
Take out the battery, put the power cord back in, turn on the machine, wait for it to get into windows, put back in the battery.
please rate
Nik
Jan 28, 2011 | Toshiba Satellite M645-S4065 Notebook
Battery loses charge, despite power cord always plugged in. Unit has a new rechargeable battery
This is very common on laptops. First take the charger to a shop to be checked. If bad, replace it. If good the problem is probably the connector where it plugs into the laptop. Unless you are very mechanicly inclined this will require a trip to the shop.
Apr 27, 2010 | Dell Inspiron 1525 Notebook
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
Computer runs off battery only not the power cord (battery is brand new)
You have a serious problem with the power and charging circuit. Normally if the battery is faulty the laptop can function with the power adapter plugged and running off the mains.
If a techo cannot fix without replacing the motherboard, then replacing the motherboard might not be a cost effective solution.
You salvage the hard drive by inserting it into an USB hard drive adapter case and use it as an external USB hard drive.
Sorry about this, you have very few options.
May 14, 2009 | Gateway MX6447 Notebook
Dell Inspiron 1525 Notebook Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
