Question about Kenmore 70125 Air Conditioner
Cannot turn the unit off with the on/off switch. all other functions work fine
    Novelist:
    Champion:
  • 246 Answers
I would replace the switch - which is something you can do I imagine.
1) just make sure all electricity is off
2) you might need to disassemble the unit just a little, but the object is to 'get to' the switch itself and then remove the wires that is plugged/attached to the switch. NOTE:: it's possible that you might have some 'burnt/shorted' wires in which case all you might need to do - is to fix the 'burnt/shorted' wires and try the AC again.
3) be sure you label each wire you take from the switch, i.e. use numbers or color code or some way for you to be able to put these wires back on a new switch.
4) once you've labeled the wires - then remove the switch and take to an appliance/parts store and buy an 'exact' replacement switch -one that has the same connections as the old one.
5) re-install it on your AC and this should fix your problem.
good luck!
Posted on May 04, 2010
MODEL FDE7970EWI
Hello, first thing click this link or copy and paste the link to your browser http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dryer-Parts/Model-FDE7970EW1/1428/0151200?searchedModel=FDE7970EWI&blt=11
this is the complete schematic to your dryer this is also the wiring schematic for the unit as well http://c.searspartsdirect.com/lis_png/PLDM/Y2704409-00006.png
One of the first things that you would check would be the door switch in the unit which if there was a fault with the door switch the unit would not turn on. By looking at the wiring diagram your unit also has a motor switch as well which if the motor switch is not depressed due to a faulty switch or the belt has broken then this could also be why your unit is not spining as well. After you check these two areas if you find both these mentioned parts are functioning properly message me back for further diagnosis. I await your reply
Thank you
Rick
Nov 19, 2011 | Dryers
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Cant get my dimplex club electric fire to come on
Do the rest of the functions of the fireplace work? If so, turn the Master On/Off Switch to OFF and plug the unit for 12 to 15 minutes. After the time has elapsed, plug the unit back it and turn the Master On/Off Switch to ON. Then turn on the flame function switch. Hopefully, that timeout allowed the unit to reset itself and the flame function is now working. If it isn't, either the flame function switch is faulty or the circuity to the light bulbs and the ro-tater motor that turns the shaft, that he bulbs are attached to, has failed. Without knowing how old the unit is and how much use it's had, it's hard to pin down one thing that is causing the problem. If it's any consolation, you are not alone. Hundreds of these electric fireplaces (all makes & models) fail every year.
If all else fails, contact Dimplex USA, Technical Service at 888-346-7539.
Hope this helped to solve your problem.
Mar 17, 2011 | Heating & Cooling
My cars signals and flashers do not work and brake lights are working . all fuses are fine what should i do
This sounds ike the multi-function switch located in the steering column. The switch can be replaced by removing the ignition switch, the upper an lower steering column covers (there are 3 screws recessed in the lower half of the column cover) Remove the 2 torx head screws from the muti-function switch (which includes the turn signal lever and the wiper switch) unplug the wiring harnesses and replace the switch.
Before doing all of that check to see if the flasher unit itself is ok. It is ocated on the back side of the fuse panel under the dash.
Jan 31, 2011 | 1996 Mercury Cougar XR7
2004 monte carlo. Turn signals dont work. The stalk still works with other functions, such as wiper, brights. The fuse is fine. Could it be a bad relay? When u push the stalk up or down nothing happens on...
try pressing the hazards on and off if they still don,t work replace the flasher unit. it is built into the hazard switch( all one unit ) change this and all will be good.
Aug 30, 2009 | 2004 Chevrolet Monte Carlo
My amp is working fine but turns off when i insert a CD
Hello pumpin_up_da,
The most likely cause for the problem you describe is that the remote turn-on lead to the amp is functional only when the head unit is operating in tuner mode. This could be caused by using a power antenna lead instead of a remote lead. Some head units have both, some only one or the other. Check the wire going to the amp remote terminal with a voltmeter. If it shows 12V when the radio is operated in tuner mode but 0V when you switch to CD, then check the wiring. If this is the cause, and your head unit has a dedicated amp turn-on lead, then connect it to the amp terminal. Most head units that have both power antenna and remote leads code them "Blue" and "Blue/White". If your head unit does not have an amp turn-on lead, you need to wire it to a 12V switched source, usually the "red" wire on most aftermarket receivers. You can then put a SPST toggle switch (available at Radio Shack or most auto parts stores) in line with the wire and turn it on and off as desired.
If the correct wire from your head unit is currently connected, then the receiver is defective and needs repair or replacement. Or, if everything else still functions normally, and really don't want to bother with repair or replacement, you can still use the 12V switched source as described above.
Hope this helps.
Jul 09, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Dvd player
you must eject the tape in order for the disc player to work
Mar 30, 2008 | Sanyo DVW-7200 DVD/VCR
Kenmore 70125 Air Conditioner Logo
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
