Question about Sony Handycam DCR-TRV17 Mini DV Digital Camcorder
I have minor audio distortion in the left channel when I record and playback. Is there a separate audio head to clean or other solution?
    Champion:
  • 287 Answers
No the audio heads are all on the video head drum. Try a head cleaning.
Posted on Apr 28, 2010
Image distorted on panasonic nv-fj620
I can't say for certain but it sounds like the video head might have gone. The good news is that you can get the parts from Curry's Partmaster website. Perhaps cheaper elsewhere? The bad news is that video heads are not cheap!
I don't know how you cleaned the head. So I would advise trying again to make certain. I would recommend cleaning with Servisol Video 40 several times. If that still doesn't work I would assume the head to have gone.
Dec 16, 2012 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Camcorder won't record or playback,has distortion and low volume.Is it just real dirty?
Try to find a video cam ,,head cleaner,,at elonric s store ,,find online,,,try cleaning the heads down in there with alcohol and a q tip,,,also,,good luck,,but thats what it is just dirty,,
Dec 23, 2011 | Quasar VM-L152 Camcorder
Have Akai GX 630 D Reel2Reel, left channel sounds dull.
THis problem could be due to heads not being clean, CLEAN, or tape head alignment needs checking. test playback with a tape you KNOW to play well on another machine...demagnetizing can also improve play and record performance. A damaged tape guide post could also be the problem but this is not likely. Lift up the hinged head cover and using a flashlight and a mirror ensure that all three heads are CLEAN and shiny...clean guide posts too. test play with a tape known to be good.
Feb 27, 2010 | Audio Players & Recorders
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
Playback distortion
Good day sir, distortion can be caused by several factors, 1. overdriven audio source, try tuning down the volume to half. 2. the speakers are defective due to driver's coil scratching the magnet. need to replace the speakers, better swap first any good known speakers. hope this may help. if you may have any more questions, feel free to ask again. thanks
Jul 18, 2009 | EMC Zotac GF6100-C-E MCP61P GeForce 6100...
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
May 02, 2008 | Sony CCP1300 Monaural 1-to-3 16x Master...
VCR jitters
Is the brake tension and alignment okay? What did you clean the drum with, fluid and stick? Did you clean the rest of the path as well - erase head, audio heads, capstan, pinch roller - etc?
Bill
Apr 26, 2008 | Televison & Video
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam DCR-TRV17 Mini DV Digital Camcorder Logo
50 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
