Question about LG LRE30453ST (Electric) Stainless Steel Range
LG LRE30453ST Electric range will not work when plugged in
The oven is not receiving power
SOURCE: LG Electric Range Oven touchpad buttons not working
Our LG range suffered from the "4" and "5" buttons not working, the large-to-small element selector not working plus several up and down functions not enabled. Technician unplugged the range, removed the back, unplugged and repluggged all the ribbon connectors. All works now.
Posted on Dec 22, 2008
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Posted on Feb 06, 2009
SOURCE: whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Posted on Mar 24, 2009
Left front burner is not turning on at all.
Gas - smell if gas is coming out and turn lights out and see if ignitor is working ,
Electric- check the wire plug connecting to burner element .
Then resubmitt your question
Dec 18, 2015 | LG LRE30453ST (Electric) Stainless Steel...
My LG electric range overheats every time it is turned on
If the sensor you changed is the rod type one in the oven itself then the only other thing possible is the control board where you set the temperature. The sensor works with that board to control oven temp.
Mar 31, 2015 | LG LRE30453ST (Electric) Stainless Steel...
What to do when PF shows on the electric panel?
the term PF means POWER FAILURE,try powering the oven down at the circuit breaker for 30 minutes to clear the computer,and during this power down check all connections to the control board,then re-power it back up,if this doesn't help then replace the control board
May 13, 2012 | Dryers
Have a lg oven lre30453st that the oven doent work the displa shows F7 clear the clock and unpluged it for 5min and still doesnt work.push the bake button it showed 375 thena second later went to...
Be sure you have 230 volts across the red and black wires at the terminal block the power cord attaches to. I suspect you have only one line to the range.
It is simpler to check a portion of the range first. Go to the relay board for the bake and broil elements. Check for incoming voltage between the red and black wires. You should have 230 volts all the time.
Set the oven control to bake at 350 degrees and check between the yellow and black wires that go to the bake element. You should have 230 volts. If you have 0 volts, check between the yellow wire that goes to the bake element and the black wire that goes to the terminal block of the range. If you have 230 volts here, the DLB relay on the relay board is bad. This will prevent bake and broil from working.
We can go through the relay board for the cooktop. I think it is best to eliminate one problem at a time.
Oct 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
LG Range LRE30453ST Error Code F-7 oven heating takes long time.
Loo I am going to tell ALL LG rang owners on thing, they worked on my top two stage burner, after that the oven either would not heat up or take for ever to come to temp. Now the oven superheats, set it to 320 degs F and it goes to over 600 deg's F. I called LG and got NO HELP AT ALL, so I went to the Consumer Products Safety Commission and filled a complaint about the range! I suggest you do the same!
Sep 13, 2011 | LG LRE30453 (Electric) Range
LG Range LRE30453ST quit working. Breaker in panel shows appropriate voltage rating, range receptacle shows appropriate voltage rating, and power cord connection shows appropriate voltage rating. The...
I can tell you aren't familar with house wiring. So we will start from the beginning. Circuit breakers are rated by the AMPERAGE that it can handle. When there is a current surge above the rated AMPERAGE the breaker is supposed to trip. When the breaker trips it doesn't always trip all the way to the side, sometime it looks okay so shut the circuit breaker off and reset it and then do it again to make sure you did it right the first time. If that does not cure your problem you might have blown your thermal fuse (Item #5016) or blown the power control board (Item #5070)
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Range-Parts/Model-LRE30453ST/3204/0124111/F0903017/00005?blt=06&prst=0&shdMod=LRE30453ST
But since the display screen is also completely blank it could be one of the PCBs in the control panel.
Aug 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
Need oven rack position for cooking meat position A,B,C,D,E,F, ?
Depends on what kind of meat you are cooking and if your roasting or broiling the meat?
Jul 19, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
LG LRE30453ST (Electric) Stainless Steel Range Logo
81 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
