Question about Poulan Weed Eater Electric Blower/Vacuum 12a
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or start the engine. It appears I should remove the white plastic starter/flywheel apparatus but the bolt will not turn independently of this apparatus. Any suggestions are appreciated.
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Posted on Jul 10, 2010
How do i fix the pull cord when it breaks
You need to take the cover off of the pulley and the spring loaded spinner, housing the rope..the pulley is sitting on the top crank shank of the motor..the spinner sits on it..the rope is attached to the spinner via a knot in a slot or hole..remove the old broken rope and measure the two parts..using an equal amount of new rope attach the new rope using the old one as an example and wrap it clockwise until there is enough rope left to be fed back through the cover..and attach the T handle Note..the T handle should have a small door on one end to feed and tie the rope on..you can see this when your remove the old rope from the T handle..should be ready to go..just watch the steps when removing the broken one and do in reverse..Good luck
Sep 30, 2014 | Weedeater 25cc 2 Cycle Gas Blower -...
The pull cord on my Craftsman gas blower model 358.794765 was jammed with about 6" sticking out. I took it apart and found nothing broken but now i cannot figure out how to put the spring in. There does...
Most likely the reason for the jamming of pull rope would be the rewind coil was over stressed due to use and age (they become brittle after a while) and where the coil catches on inside of housing snapped causing a slight unwinding and then the restricted movement of pull rope assembly. If you have it apart you should be able to see where the coil connects at both ends and attaches to its mating location. If you do not see the typical bent coil hook then your coil is broken. No worries, if this is the case, heat the broken end with a lighter or torch and use a pair of needle nose pliers and reshape to match the hooking location. Once completed, rewind coil and place masking tape around coil temporarily holding coil in place and leave yourself about three inch lead of coil to attach where it needs to go. Insert and fasten coil assembly then remove all pieces of tape. At this time your pull rope should be recoiling and rewinding pull rope. Always wear eye protection.
Sep 03, 2013 | Craftsman Garden
How to rewind pull start rope ryobi gas blower ry09550
you need to pull it all the way out at the roller/wheel, get screw driver or some thing that can jam it not to let it roll back, and tight the rope to it and make sure not to slip the rope, and hold the roller/ wheel until you done with the rope, and release the roller/ wheel gentle slowly, let it wind in the rope.
Jul 24, 2013 | Ryobi Gas Blowers Models Ry09550
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
The pull chord is jammed on my FL 1500 LE. How do I get it loose?
Unfortunately,its not jammed,you need a new starter clutch mechanism,I have a similar problem,if you can get one from your agent/supplier its quite easy to do yourself,you should be able to download a pdf manual from the internetrgds
Sep 26, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
The pull cord on my homelite weedeater is jamming and not able to pull it all the way... can't see anything that is jamming it and does not appear broken.
Sounds like the cord is caught in a slot on the side of the pulley the rope recoils into. The cover will have to be removed and maybe some additional things but it can be fixed fairly easy with some patience.
Jun 09, 2010 | Homelite Garden
Weedeater pull cord won't pull out on a leaf blower
Suggest to remove recoil housing/assembly and try to rotate the flywheel. Remove the spark plug & check for a silver or aluminum color or coating.
If the flywheel will not turn by hand, the piston/cylinder is seezed. No further repair is affordable.
If the flywheel turns by hand and the spark plug is a dark brown color, then focus your attention to the recoil assembly to see if rope is bound or wound around the rope rotor.
Nov 10, 2009 | Poulan Garden
Repalce cord on gas blower
MAKE SURE YOU HAVE THE RIGHT SIZE CHORD FOR THAT STYLE,MUCH SMALLER THAN MOWER STYLE. ALSO PROBABLY HAVE IMPROPER TRACKING OF ROPE. TRY PULLING COVER BACK OFF AND MAYBE KNOT GETTING CAUGHT UP IN FLYWHEEL FROM ROPE
Jul 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Clutch
Two things, The rope pulley has lugs on it for the flywheel pawls, the lugs are worn off mainly due to pulling the rope before the pawls engage. replace plastic pulley..
the flywheel pawls are siezed in the run position full of dirt or rust clean and free up.
Jan 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan Weed Eater Electric Blower/Vacuum 12a Logo
1,058 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
