Question about Sony Playstation 3 (PS3) Console
When I turn my console on nothing happens, I take the hard drive out and hold the button to reset it twice then put the hard drive back in it works perfect, until I turn it off. Then I have to repeat the whole process
  • darrellhudso Apr 27, 2010
    What is that, can I do the work myself
    The green light come on like it booting up but the screen stays blank
  • 1,472 Answers
Darrellhudso
To clarify when you mean nothing happens does this mean that you just get no video and the PS3 turns on (IE you get a Blue/Green light or does the PS3 stay off with a read light.
Issken
http://www.fixya.com/users/issken
Posted on Apr 27, 2010
  • Will Hartford
    Will Hartford Apr 28, 2010
    darrellhudso
    It you arre getting the green light this means that the PS3 is starting properly. Since you keep reseting the video it sounds you may have some corupted setting on the PS3.
    Question, are you using the AV connection or HDMI connection and have you switched between that at any time.
    Issken
  • 661 Answers
I am sorry to say but this unit is defective. It needs sent in for repair. Sounds like one of those itty ***** transistors burned out.
  • Bryan Fullerton
    Bryan Fullerton Apr 27, 2010
    Sorry I dont think so unless you are an electronics expert. In school for electronics and have the special equipment and magnifying lenses for working with very small electronics.
Console turns on fine but just back drop appears and stays nothing else happens any help please
hold the power button until it beeps once this is known as a soft reset. then do the setup and see if it works. If not hold the power button until it beeps twice this is the master reset. select restore system settings and try it again. If it still doesnt work your Hard drive may be damaged. If you replace your hard drive and still have the problem its your motherboard. a new HD will run you anywhere from 39.99 to 129.99 depending on the GB you want a new motherboard would run you anywhere from 20.00 to 40.00
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
Hard drive not responding, comes up with message restore hard drive. when you do this the message just comes back.
Wendy.
Breathe. :)
Now, hold the power button down until the system turns on and turns back off.
Now, then let the button go. Then hold the button down again it will beep once then beep twice quickly. Then let it go. It will tell you to plug in the usb cord and connect the controller then press the ps button.
A menu will apear - select option #5 (System Restore).
Simply AGREE with everything it tells you until completed. You will need to reset the time and date on the unit, but this should correct the issue.
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
When i try to turn on the system i get a yellow light then it beeps twice and the light flashes red and it wont turn on or eject my game ive tried holding down the disc eject for 10 seconds and nothing is...
turn off your ps3 to then just press and hold the eject untill the disc comes out as for the ylod you need to replace thermal paste on the gpu and cpu goto llamas.com to see tutorials and try pulling hard drive out and resetting it back in place
Oct 13, 2010 | Sony Playstation 3 (PS3) Console
My playstation turns on but nothing happens after that. There is no display or sound output. It will not turn off, gibving two beeps if you try to shut it down. The hard drive light comes on for about...
hello try resetting it turn the ps3 on then press and hold the standby button you should hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset it self
regards
shaun
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
Power went off suddenly and now my light is blinking red what happened?
Make sure the PS3 is turned off. Take out the hard drive from the PS3 and then put it back in. Now turn the system on and see if that takes care of the problem.
If that doesn't work then turn off the PS3. Hold down the power button in the front and turn on the PS3 in the back, it will make a beeping sound, once it does that then let go of the power button on the front and see if you get video, this will reset the PS3 to factory defaults.
If this doesn't work then that means either the power supply is bad or the motherboard is bad.
May 06, 2010 | Sony Playstation 3 (PS3) Console
Red light on power supply on. Nothing happening on the x box console. dead.
The blinking red light usually indicates hardware failure. If your Xbox is still under warranty you should contact microsoft have them send you a box with free postage and send them your console. They will locate and fix the problem for you.
If your console is not under warranty anymore there are a few things you can try.
First remove the hard drive and try booting up your console. If it says no drive found shut the console down and put the hard drive back into place. If it works after that then the issue was just a drive error which is now corrected. If the light is blinking again then the drive itself is bad.
Second turn the xbox off for 60 seconds by using the switch on the back. Now hold down the eject button and turn the power switch back on while your still holding the eject button. This can help with overheating issues.
If these simple fixes dont resolve the problem then you will need to contact microsoft and ask about repair cost's. As fixing it yourself would require experience in working on gaming consoles.
Jan 17, 2010 | Microsoft Xbox Console
My grandsons PS3 turns on but it just shows a blank screen, we are using av cables. I found how to get into the diagnostic mode and this part works but it did not fix anything. The light turns green but...
The ps3 automatically detects an HDMI cable not av cables. You are going to have to reset the video settings back to factory. This can be done by turning the unit completely off(Hold the power button until you see a red light. Then turn the power switch off in the back. If you do not turn it off in this order, and just turn the switch off in the back it can corrupt your hard drive!). Once the unit is all the way off, hold you finger down on the power button in the front. While continuing to hold the power button in the front, turn the switch on in the back. After several seconds, you should hear a couple beeps. This confirms the video settings have been reset. Don't get discouraged if it does not work on the first try. It sometimes takes several attempts. If you have any further questions feel free to contact www.wiredextreme.com.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont come on loads up but just a black screen
This is usually how they boot up with no hard drive installed. See how it starts with the hard drive removed. Try after you reseat the hard drive. Try a different hard drive. Good Luck
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
I turn on my ps3 it comes on but i get no icons only a black screen
Try reseting your display. To do this turn your ps3 off if it isnt already, turn it back on and continue to hold the power button until you hear the beeps. It should reset your display if that is the problem.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
