Question about Electrolux Centralux Vacuum
I have an aerus central vac. When I took it apart to try and clean ther motor the wiring came off. where can I get the info I need to rewire
  • 694 Answers
Go to http://aerushome.com/ to locate an authorized shop near you.
Their service department will have the info, but generally will require the machine to be brought in to be repaired.
Posted on Aug 22, 2010
What? Kenmore central vac S107 34089?
Sounds like it's overheating and tripping the thermal breaker. The motor housing should have some ventilation (cooling) ports or slots. Inspect them carefully and remove any clogs and debris you find.
May 25, 2014 | Vacuums
Mini shop vac
There is a hidden thermo fuse in the tape on one of the field windings. If it overheats that fuse will blow and the motor won't run until replaced.
May 22, 2013 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Model 1580 central vac electrolua stopped burning smell
If the smell is like burning metal and very strong, the motor is bad and needs replaced.
The circuit board inside could also have shorted and burned out. You can check the motor by removing the low voltage wiring from the side of the vacuum and using long-nosed pliers. Open the pliers and slip a point into each terminal. The motor should come on if it's still good. If it does run, the problem is with the relay board.
Although you can get either motor or board and replace them yourself, if you let the tech at an authorized Aerus Electrolux store do it, there's a one year warranty on the part/s and labor.
The nearest store can be found using the following link.
http://www.aerushome.com/storelocator/
Mar 02, 2011 | Electrolux Central Vacuum
I have an electrolux central vacuum in my house. My central vac hose has something stuck in it, I think, maybe a sock. I tried to put a long dryer wand down it but the hose is just too long. Does this need...
The best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked".
Jan 03, 2011 | Electrolux Central Vacuum
I have a 20yr old electrolux central vac that the motor just went bad. in wondering whether to replace motor or replace whole unit i have found an electrolux unit and a aerus unit. someone told me elect....
Motor to replace or rebuild:
Depending if your motor just started to get noisy, you can take it to a private vacuum repair shop and most rebuild for around $80 to $100.00. Usually they replace top/bottom bearing and the armature carbon brushes.
If it's loud and vibrating and probably sparking. Do not bother to rebuild, the armature is now probably damaged and not worth the new parts.
Replacing the motor is pretty basic and usually saves you about $150.00. They're pretty simple to release out of the unit and are pretty simple to remove and reinstall.
To find out your replacement motor number you will need to find the stamped model number on the motor itselt. It is a 6-8 digit number. That is the Ametek Motor Model number. Ametek is used in pretty well all central vacuum systems. Motors range from $99 to $239.00
www.ametekfsm.com/Product_Compare.aspx?MT=1&MST=1&FanStyle=Bypass&Discharge=Tangential
Dec 30, 2010 | Electrolux Centralux Vacuum
My central vac unit does not turn off even when hose is disconnected. I have to unplug the motor unit in the garage to shut it off. What do you think the problem is? It is a 7 year old Electrolux
Possibly the power module. Or a short in the wiring. Take it to the local Aerus Electrolux store and have it checked by a service tech to be sure. The pm is a lot less expensive to replace than a whole cv.
Nov 21, 2010 | Electrolux Central Vacuum
My Electrolux Aerus central vac is overheating due to a broken metal fan that spins on top of the motor,must be to cool it. The center piece of the fan has come apart and the piece just sits on top of the...
Check with your local dealer. Electrolux dealerships are the only place to get the part. Call them to send someone knowledgeable out to check the machine. Depending on the age of your vacuum, it may still be under warranty. If the broken fan is not due to abuse or normal wear and tear, then the warranty should cover it.
Aug 16, 2010 | Electrolux Centralux Vacuum
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Electrolux Centralux Vacuum Logo
115 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
