Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Need to replace starter
Do yoiu have to remove the flywheel to remove the starter on model 303447 type 1079-A1 Code 904011 engine? If not how do you remove the starter
  • skyking24 Apr 27, 2010
    It's on a Middleworth riding mower. The engine has been pulled from the mower
  • skyking24 Apr 28, 2010
    Could you please resent your last reply I could't open it.
    Thanks
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Your parts manual that I will make reference to is here: http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=MS9691_LO.pdf
Before you start to replace the starter disconect the negative battery terminal.
The flywheel does not have to come off. There are 2 mounting screws on the drive / bendix end of the starter that need removed Item 1009 on page 18 of the parts listing above. Then the whole starter will drop down. Once you have to old starter free, start transferring electrical connections to the new starter one at time. After all electrical connections have been moved mount the new starter.
Connect the negative battery cable.
Disconnect the spark plug wires and test starter. (i.e. you don't want the engine to start yet) Make sure is does not grind excessively when in use. If it does grind or make an odd noise you will need to reposition the starter by losening the mounting screws (Item 1009) just enough so that you can slide the starter a bit and move the starter to a new position. Retighten the mounting screws. Test again. Repeat repositoning as necessary to eliminate odd noises.
Reconnect the spark plug wires.
Place unit in service.
I am not sure if you have to remove the air shroud on this engine to gain access to the starter mounting screws. Some engines you have to lift the shroud up to change the starter. Others it is just a matter of removing the screws. If you have to lift the shroud make sure that is is NOT touching the flywheel when you perform the starter test.
Thanks for using FixYa.
Kelly
Posted on Apr 28, 2010
  • Kelly
    Kelly Apr 29, 2010
    This is a duplicate of my last post. If you having trouble with the link. Right click the link and then choose "save as" and then open the file after the file downloads. It will open with adobe reader 8 or sun microsystems "open office" writer.
    http://www.briggsandstratton.com/maint_r...
    Kelly
  • 12,061 Answers
Http://www.ehow.com/videos-on_553_lawn-mower-starter-repair.html
http://www.wonderhowto.com/topic/replace-starter-on-riding-mower/
http://www.m-and-d.com/MTD_Parts.html
Above exploded parts lists, above that, diy replace starter.
http://www.petessmallengine.com/html/page_157.html
he flywheel has a recessed pocket on the under side that when rotated to the proper position will allow you to take the inner-most bolt out so that you can remove the starter. The outboard bolt is no problem at all. Just remember to remove one of the battery cables so you won't have to worry about shorting out a wrench while you are removing the cable on the side of the starter.
The square shaft which turns one direction but not the other is the recoil starter pawl. This can be pulled straight up from the round cup that it sits in. There should be a couple of steel balls inside. Some models have a large internal snap ring that holds this in the cup. Remove ring, and pull it straight up. Use a magnet to remove the steel balls. Once you have this starter pawl removed, and the steel balls, hold the flywheel, stationary, and using a block of wood, bump one of the lugs on the outside of the starter cup in a CCW direction.
Once you break it free of its torque, it should be able to be spun off CCW. Remove this starter cup, and the beveled bellville washer under it. Now your ready for your flywheel puller. A strap wrench can also be used to turn this starter cup loose. When installing the starter cup, make sure it is clean and free of grease and oils. A drop of oil or a light coating of grease on the crankshafts stub end (over which the starter pawl goes) is usually recommended. The starter cup only needs to be snugged down, and you don't have to go overboard trying to torque it to ungodly tightness. Snug is sufficient.
Drop in the starter pawl, into the cup over the stub of the crank, and drop in the steel balls, replace larger flat cover over this assy, and insert snap ring if there was one.
appcoracing.net/briggs.pdf
manual exploded parts. above.
That should help you.
  • 15,935 Answers
What machine is this on?
Thanks!
Posted on Apr 27, 2010
My starter is engaging but it is not hitting the flywheel to let it turn the engine over could that be from a bad flywheel or not haveing the shims in the starter
Yes and yes, but if you are lucky it could be a bad starter bendix. Remove starter to examine and check flywheel teeth as well.
Jun 20, 2016 | Cars & Trucks
My 1999 Aprilia RSV Mille starter turns (can here it whirring) but does not crank the engine
The starter clutch is failed. The starter clutch is located on the back of the flywheel, so you'll have to remove the flywheel. The flywheel is difficult to remove and sometimes requires heat (torch) along with a three bolt type puller. Once the flywheel is off, the repair is fairly straight forward. Just remove the old clutch, paying attention to the direction of the rollers, and install the new one. The gear on the flywheel should also be replaced to insure good performance of the new clutch and starting system.
Sep 07, 2013 | Aprilia Motorcycles
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
Where is the starter located on 1985 Honda Civic?
The starter is located on the firewall side of the engine block, adjacent to the flywheel or torque converter housing. Early models, use a direct drive type starter, while the later models use a gear reduction starter. Otherwise, the two units are similar in operation and service. Both starters are 4-pole, series wound, DC units to which an outboard solenoid is mounted. When the ignition switch is turned to the start position, the solenoid armature is drawn in, engaging the starter pinion with the flywheel. When the starter pinion and flywheel are fully engaged, the solenoid armature closes the main contacts for the starter, causing the starter to crank the engine. When the engine starts, the increased speed of the flywheel causes the gear to overrun the starter clutch and rotor. The gear continues in full mesh until the ignition is switched from the start to the on position, interrupting the starter current. The shift lever spring then returns the gear to its neutral position.
Begin the starter removal by first disconnecting the wires leading to it
Hope helps (remember rated this).
Jul 14, 2010 | 1985 Honda Civic
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Where is the starter located?
Honda Accord/Prelude 1984-1995 Repair Guide
Starter
Accords and Preludes may be fitted with either a direct-drive starter or a gear reduction starter. The differences are internal and depend on the manufacturer of the starter.
The two units are similar in operation and service. Both starters are 4-pole, series wound, DC units to which an outboard solenoid is mounted. When the ignition switch is turned to the START position, the solenoid armature is drawn in, engaging the starter pinion with the engine flywheel. When the starter pinion and flywheel are fully engaged, the solenoid armature closes the main contacts for the starter, causing the starter to crank the engine
When the engine starts, the increased speed of the flywheel causes the gear to overrun the starter clutch and rotor. The gear continues in full mesh until the ignition is released from the START to the ON position, interrupting the starter current. A spring then returns the gear to its neutral position.
REMOVAL & INSTALLATION
  1. Disconnect both battery terminals, negative first.
  2. Disconnect the large cable from the starter motor; label and disconnect the wiring to the starter solenoid. Certain engine/transmission combinations have an engine harness secured in a clip on the starter or transaxle. Remove the harness from the clip and position it out of the way.
Fig. 1: Gear reduction starter used on some Honda models
Fig. 2: Direct-drive starter used on some Honda models
  1. Remove the starter motor by loosening the attaching bolts.
To install:
  1. To install, reverse the removal procedures. Tighten the starter-to-engine bolts to 47 ft. lbs. (64 Nm) on the Accord V-6 and 32 ft. lbs. (45 Nm) on other models.
  2. Connect the wiring to the starter securely.
  3. Connect the battery cables, positive cable first.
STARTER SOLENOID REPLACEMENT
  1. Remove the starter from the vehicle.
  2. Remove the screws securing the solenoid to the starter housing.
  3. Pull out the solenoid. On the Nippodenso type, there is a spring on the shaft and a steel ball at the end of the shaft, be sure not to lose them. On the Mitsuba type, move the solenoid away from the plane of the armature to disengage it from the solenoid lever.
To install:
  1. Install the solenoid with a new gasket (if equipped). On the Mitsuba type, make certain the lever is correctly installed to, and engaged with, the lever. On the Nippodenso unit, make certain the steel ball and spring are correctly placed. All the sliding surfaces of the solenoid should be lightly greased before installation.
  2. Tighten the retaining screws until snug.
  3. Install the starter.
Good luck (remember rated and comment this post).
Mar 02, 2010 | 1989 Honda Prelude
How to replace starter ring on husqvarna yt130 with B & S 13hp engine. I have removed the flywheel. Nylon starter ring appears to be riveted on. Can I buy the ring only or do I buy the flywheel...
Briggs offers a kit to replace the plastic ring gear with an aluminum ring gear. Remove the gear by drilling the rivets and punching them out. The kit comes with bolts, ring gear, and starter gear, plus instructions. Go to your local briggs dealer with the model, type, code numbers of the engine. Aprox $40 cost. If you cannot find a dealer, I can offer the part to you. thanks, mowerguy
Nov 08, 2009 | Husqvarna Garden
Model 350447 type 1118-A1 code 96121911 my starter turns and makes noise, but doesn't turn the engine --- won't start
This Briggs engine has a plastic bendix gear on the end of the starter that maybe worn out. You can replace just the bendix if everything else is ok
Sep 25, 2009 | Woods Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
101 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
