Question about Mitsubishi WS-55511 55" Rear Projection Television
Green light turns on and 2 seconds later it shuts off
My tv wont work
    Scholar:
  • 62 Answers
The DM board has gone bad and not letting the tv boot. Stdby supply neeeds to be looked into, This board in in a metal box generally on the left side of the input connections panel when seen from behind. Can cost $ 140 to 280 to get professionally repaired depending on the problem.
Posted on Apr 27, 2010
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
