Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Heather wont come on, filter is clean - Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
  • 33 Answers
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
Meaning of the name Heather
  1. The name Heather is an English baby name. In English the meaning of the name Heather is: A flowering evergreen plant that thrives on peaty barren lands as in Scotland. Heather.
Jun 13, 2015 | Computers & Internet
Replaced ignition and charged battery
Hi Heather:
I'm guessing it won't start?
Check for a hot blue spark at the plug.
Fresh gas?
Clean air filter?
Switches on?
Should run.
May 13, 2015 | Garden
Intake duct
Check Under wiper rod cover near windsheild where Heather take is air or pollen particule filter
Apr 23, 2014 | Ford Escape Cars & Trucks
Po106 code chrysler town country
Hi Heather, I'm glad to help! Heather, provided you have a good vacuum going to the Map Sensor and wiring and connectors are good. That would be the first thing I would replace. But, if after checking wiring and connectors and a good vacuum you replace the map sensor and still have the code I would have it check out for a possible (PCM) Powertrain Control Module. Hope this helps and have an awesome day Heather!
Apr 17, 2014 | 1996 Chrysler Town & Country
Hi ,i have a renault scenic 99 model and my heater sonnds like its working on all 4 positions but i cant hardly feel anything , any ideas what could be wrong or do i need a new motor.
I had the same issue and it turned out to be the pollen filter. It was located in the passenger side footwell secured by a single 6mm bolt. Unscrew the bolt, slide the cover off and pull the filter out. I was feeling cheap so I only cleaned out the filter rather than replace it but after doing this I once again could feel some air coming through all the heather vents.
Mar 04, 2010 | 1986 Renault Sport
My Laars will turn on. Was waming jucuzzi then stopped and won't turn on.
it got hot and this means it did not have the right amount of water flowing trow the Heather is was less than normal causing the heather to get to hot and the high limit switch kick the heater off other mayor problem is with the temperature sensor located right in the heather outlet line make sure your filter is clean most problems occurred because the filter get dirty
Jun 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater will not stay on
when a heater runs for 30 seconds or les some heaters run or about 1 minute this is mostly a problem with how much water is getting in the heater if is too little the pressure switch cuts the heater off or the high limit switch is shutting off the boiler why because the small amount of water getting inside your heater get hot to fast and make the heather to get so hot and the high limit switch turns the heater off the solution is to check your filter make sure is clean or cleaned they get dirty soon if your filter is clean and still doing it check the bypass in the heater normally is located next to the lines going in and out in the heather lines I have fix so many heaters my self I use to have a business in california as swimming pools repair so I know this and your heater is not to big to say is your gas regulator gs regulator is a common problem on heaters ranging on size from 30-36-40 BTU
Jun 14, 2009 | Pentair Minimax NT Heater
Suction
Hi.
If you have checked & cleaned all filters & its still no good go to this site http://dysonmanuals.llc.nu/index.htm
Then contact page you require DYSON DISC (1) DC07 NO/POOR SUCTION O/HEATING.
This will sort out your problem.
May 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Heating & Cooling Logo
317 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
