Question about Kenmore Elite 45986 Front Load Washer
Large Appliances When the washer drains it smells like ammonia. I have changed the drain hose and run empty cyles with bleach or vinegar to try to cut whatever is in there. Any help out there.
    Genius:
  • 1,554 Answers
Start by cleaning out the filter in bottom,
remove the access panel bottom 3 screws , open filter , some excess water will spill ,
clean it out,
next clean under the rubber flap around front of drum.
run borax through a cycle.
run clorox in a cold cycle
the issue may be that the back of the drum is coated with waxy goop from using too much softener,
Posted on Mar 26, 2008
How do I get my clothes to SMELL like clean clothes? Darn washing machine stinks them up!
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
Aug 18, 2014 | Maytag Centennial MTW5800TW Top Load...
Why do the clothes not smell nice
You might try running an empty load with hot water and bleach to clean out the washer. If it's a front load washer, high efficient detergent is recommended. Using the wrong type of detergent (or too much) can cause the undissolved detergent to sour over time and smell. Look for any hidden garment around the boot or in the duct that allows water into the tub, at the boot. Make sure the drain hose is not air tight at the drain pipe. Sometimes a siphon break may be needed at the stand pipe where the drain hose connects.
Feb 12, 2011 | Dyson Memory CRO1 Front Load Washer
The water smells bad as if it is not draining correctly. Is there a water filter that needs to be replaced? How do I clean out this washer to get it smelling nice?
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps.. Please post back if you need mor information.
Daniel
Nov 26, 2010 | Bosch WFMC 3200 Front Load Washer
Our clothes are coming out of the washer with a rotten smell. I have tried Tied Washing Machine cleaner and the vinegar/soda mix...but no change.
Try running a cycle, at highest level, with hot water. When the tub is about ready to drain, connect the drain hose to a water hose, and let it drain through the water hose to outside. See if the water has a smell / any "floaties" that may indicate a mold / mildew growing inside the agitator. You can try to over fill (fill to highest level, then add water using a bucket) with water and add a large amount of bleach. Let it sit overnight, and run a few cycles to rinse out the bleach residue
Have you noticed a similar smell from the hot water when taking a shower / doing dishes / washing hands? You could have bacteria growing in your water heater. Shocking it (with granulized bleach - see owners manual) will help clear this up. If you are on a well, you may also be getting sulfur or Hydrogen Sulfide (H2S) into your well water as well.
Aug 19, 2010 | GE WJSR2070B Top Load Washer
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The problem is design. Not all of the water is getting out after each cycle and not all of the soap gets fully dissolved. After awhile, this mucky slime gets 1n the drain hoses, pump and filter - and they all smell musty - especially when the machine sits empty with the door closed between loads.
You need to clean the innards of the machine by doing a load without clothes on hottest setting (Whites) and depending whether the smell is bacterial (add 1 cup White Vinegar), fungal (add 1 Cup Bleach) or clogged filter (add 1cup Arm and Hammer with 1/4 cup SALT), this should do it
(Vinegar for Bacteria, Bleach for Fungus and Arm and Hammer with SALT to soften and loosen the slime)
Choose from above (not all 3 at once tho) and fill the machine with water and let run without clothes.
I would do the A&H with salt first, let cycle complete, then restart and add a cup of Vinegar, tel cycle finish then redo with 1 cup bleach
After treatment, leave the front door open after doing laundry from now on so it can thoroughly dry out and get air circulation. - Just open, not WIDE open ;-)
Cheers!
Mar 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smell in washer
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Smelly drain water
I had the exact same problem and all of my clothes smelled like mildew. I switched to laundry detergent for front loaders ONLY and have eliminated this all together.
Run an empty cycle one time with 1cup of white vinegar.
Then start washing with the new detergent.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
