Question about Hammering
I would like to add a outlet to an existing outlet
I would like to add a plug to an existing outlet with two light switches. I could I email a photo of the outlet with the wires and switches stretched out for better viewing. This may make the question easier to solve.
Cheers
    New Friend:
  • 81 Answers
You will need to wire the outlet, and then run a jumper from the white to the white on switch 1 and 2.
you will need to wire the end switch and middle swtiches normally with the ground and black wires.
the white wire jumpers will run from outlet (GFI if in a bathroom), to middle switch hot, to end switch hot.
Posted on Apr 27, 2010
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
Add 12 volt outlet switched by ignition
Look in your owners manual for the accessory fuse. That line turns off. Also, consider a 12 volt relay between the seat and your power source. A small toggle switch will work well for a relay.
Dec 13, 2013 | 2005 Pontiac Montana SV6
I want to use a TM8111 swithch to control 3 devices. A ceiling fan/light combo, night light and a vanity light. How do I hook it up?
Following image has basic wiring plan.
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Each Load (light-or-fan) has to have separate wire running to switch box.
If night light is plugged into wall outlet, then a new wire will have to be added going to switch box.
Most night lights have built in photo eye, and on-off switch.
Add a comment for more help and include specific wiring and what you have tried so far.
Jun 14, 2011 | Pass & Seymour Legrand TM8111 Three Single...
Have switch 691-WCC6. Replacing an old outlet with no ground wire - have 2 black and 2 white wires coming out of box. Looks like two brass connections on one side and silver one on the other side with a...
Question is posted under switch, but asks about outlet.
Outlet is where you plug extension cord for example.
Usually screws are color-coded.
Outlets have brass and silver screws.
Without testing wires, trying hooking wires to same color screw they came from.
If breaker blows, then take off one wire and try again, or test wires to see what each is connected to.
As general rule with newer wiring inside outlet box, code says Black wires are Hot and go to brass screws, White wires are neutral and go to silver screws.
Older wiring could be very different especially if wiring was not done by code.
Use cheap circuit analyzer from home center to help diagnose outlet problems.
Add a comment with photo of your old wiring device, plus wiring.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 10, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have a cooper switch in my RV. It controls the electric side of my hot water heater. There is a little red lite on the switch that comes on when the switch is on. The red lite has gone off however I...
Yes the indicator light can go bad.
Google search: 'cooper switch with indicator light' -or- 'cooper pilot light switch'
Double check amp rating on existing switch to make sure you have correct amperage.
When replacing switch, look at screw colors and location of wires.
Compare screw colors on new switch.
Screws are color-coded and wires attach to same color screw.
Take photo of wiring or draw picture of wiring before taking out old switch.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on switch or any
do-it-yourself project.
Jan 13, 2011 | Cooper Industries Cooper Wiring 274W...
Diagramed instructions of how to use an existing 110 outlet and make another outlet/lightswitch
http://waterheatertimer.org/images/lights-400.jpg
The link above shows basic wiring plan for adding a switch
The switch always turns the Hot wire on-and-off.
When selecting wire size, use same size that connects to plug
So if plug has a yellow-sheathed cable, then use #12 wire
If plug has white sheathed cable, use #14 wire
#14 is smaller wire than #12
http://waterheatertimer.org/RomexC.html
The link above shows how to install wires in octagon box
Your light fixture always attaches to octagon box.
Octagon box can be round, it can be made of plastic.
The box can be nailed to any surface.
http://waterheatertimer.org/Install-owb.html
The link above shows how to add a switch box in existing wall
They also sell octagon boxes that insert into existing wall or ceiling.
http://waterheatertimer.org/How-to-twist-electric-wire.html
The link above shows some basic electrical techniques and
links to wire nuts and wire size
Oct 31, 2010 | Garden
I want to use an X-10 Pro appliance module outside, in an outlet that has a Leviton outdoor covered electrical outlet cover. The appliance module does not fit even with the cover completely open. Is it...
Instead of trying to put your appliance module outside, and risk it getting wet, why not add another outlet inside the house, near the existing outdoor outlet, or anywhere along the path of the existing wire that feeds that outlet. Re-route the wires that were going to the outdoor outlet to this new outlet instead. Then plug the appliance module into the new outlet, and plug into that a new wire leading to the existing outdoor outlet. If you are really lucky, there will be enough slack wire so that you can cut the wire going to the outlet and insert the new outlet in-between. In any case, you will need to put a plug on the wire feeding the outdoor outlet. Work safe, don't forget to turn off the breaker first! Good luck.
Jun 17, 2010 | Leviton Weather Resistant Outdoor Switch...
I have a Leviton 5625 (rocker switch and outlet) and am trying to replace an existing light switch with it. I have a black and white wire tied to the top and bottom left screws, respectively, in the...
Ok - you have to figure out which two wires are supplying the power. Then which wires go to the outlet. Then the last wires should go to the light. Connect all the white wires together. then the black from the power cable goes to the black of the outlet. Add a short wire to the black group and put it to one side of the switch. put the black wire from the light cable to the other side of the switch.
Nov 20, 2009 | Electrical Supplies
Hammering Logo
51 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
