test this steps and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal
fuse might have blown. The thermal fuse helps to prevent damage to the
dishwasher by turning off power so that it doesn't overheat. Once blown,
the thermal fuse will have to be replaced for the dishwasher to work.
The thermal fuse is usually located in the control panel on the control
board or mounted to the bottom of the tank behind the lower panel. The
thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes
called interlock switches. The door switch prevents the dishwasher from
running while the door is open. If the dishwasher won't start, the
switch or switches might be defective. To access the door switches,
remove the control panel or inside door panel - depending on the model.
They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door
latch assembly might be defective. These are normally made of plastic
and cannot be repaired. If the door won't latch and the door latch is
broken, replace it.
Main Control Board
The main control board provides power to
nearly every component of the dishwasher. If the dishwasher won't start
the main control board might be defective. You should first check for
more common parts. Many times control boards are replaced unnecessarily
because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control
board might not get the signal for the selections made. If the
dishwasher won't start and the display doesn't seem to change properly
when the buttons are pressed, the touchpad might need to be replaced. On
some models the touchpad and control panel are sold together and will
need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper
parts at the proper times. If the dishwasher won't start, the timer
might be defective. Keep in mind that timers are often misdiagnosed as
the cause of a problem. Check other components first before replacing
the timer.
