Question about Rockford Fosgate Car Audio & Video
Wires on my amp touched now its not turning on and
Someone tried to steal my subwoofer and they cut the wires so i used electrial tape but my subwoofer wasnt bolted down now the radio and the amp doesnt work
  • nikijerry4 Apr 27, 2010
    my amp stopped working i appplied electrial tape to wires but i didnt bolt down the subwoofer and the came loose what happen
  • Rockford Fos... Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. Double check all connec
.A thumbs up would be greatly appreciated if this answer is helpful to you. wires on my amp touched now its not turning on and - wires-amp-touched-now-its-not-turning-peeu4x5nsxvd53n2rwetiqa4-3-0.png
Posted on Dec 19, 2014
    Genius:
  • 1,040 Answers
Hi... Nikjerry...!
Nice to see you..
For best music output wires should not have joints. So Replace the taped wire....
I was also suffering from the same problem for home music system. When I replacing wire everything is works fine....
Posted on Apr 27, 2010
  • 713 Answers
Hi,i think you should check the wiring connection from the battery to the radio unit,there is probably disconnected wire from the battery which supplies power to the unit,particularly the places you applied the electrical tapes,also ensure to bolt down the radio properly because constant distortion of the radio from its desired position might affect the server unit of the device. However,its a power problem,so ensure you carry out a thorough check on the wiring power connections in your car.
Thanks and take care
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
I hooked up a Sony deck and new Kenwood 12' subwoofers and amp that came together in a box set in my 95 Jeep Grand Cherokee and when I play the radio the stock car speakers play but the subwoofers are...
their should be a blue and blue white wire on the Sony radio. cut the blue wire and then connect the car side to the blue white wire and tape off the blue wire that is on the radio side.
the blue wire only turns on when the radio is activated. the blue white wire is activated when the radio is turned on.
please rate my solution.
Jul 02, 2011 | AudioBahn Car Audio & Video
Hi,someone tried to steal my xt125,they cut the wires,any idea how to re join the wires as they are not colour coded,thanks
what wires do you put together on a xt 125 to get it started?? some1 tried stealing mine but not got away with it
Jan 08, 2011 | 2006 Yamaha XT 125 X
My inside highs cut out . want causes this?
Alot of amps and speaker crossover have protection circuits built into them so when you turn up the music to much it's there so you don't blow your speakers. Try turning down the gain on the amp if that does'nt work check your speaker wiring for out of phase meaning
+ - wires are backwards. To test them use a 9v Battery touch the speaker wire to the + - terminals on the battery if the speaker pops out it's inphase and good if it pops in it is out of phase reverse wires and if all that checks out get a stonger amp.
Apr 20, 2010 | Sony Car Audio & Video
I put an after market cd player in my 2003 acura 3.2 tl type s. all the speakers are working fine but i am not getting any sound out of the factory subwoofer, it is not working. any idead what i did wrong...
You got to connect the blue amp turn on wire. If still dont work. then you got to find the factory amp find the two wires that sends frequency signals to the amp. You will see a total of 7 wires. So you've got to use process of elimination. Use a multimeter.
1.Constant 12 Volt
2. Ground
3. Amp turn on
4. + output wires going to the + of the subwoofer
5. - output wires going to the - of the subwoofer
6 + input wires going to the radio harness
7 + input wires going to the radio harness
6 & 7 are like the rca's you plug in at the input of an aftermarket amplifier and and on the other end plug in the output subwoofer of the Radio.
So on a factory amp you wont see any RCA's its all wires. Once you find the first 5 just remember the last 2 wires.
If you want your radio to control the gain and volume of the Subwoofer get a long RCA plug it on the back of your radio that says sub output and then cut the other end of that RCA and connect the positive the + input wire on the amp and the negative to the negative input wire on the amp.
If you dont know whats positive or negative just go ahead and connect it and experiment. You will know if your in phase when the subs sound boomy. Then the connections are correct. If it sounds Tinney then the connection is out of phase. solder then tape all connections with black electrical tape. Dont leave any power wires exposed or else cause a short and blow fuses.
Good luck
Apr 07, 2010 | Car Audio & Video
The wires that are connecting the speaker to + & -
Soder the connection on there. The wires used are just basic speaker wire.
Oct 09, 2009 | Bazooka CSW1004 Car Speaker
My PG Xenon 600 watt amp will not power my subwoofers
hello it sounds like your problem may be in the remote/power wire that goes from the back of your radio deck to the amplifier. the amp should have a wire connection that says remote,p.con, or antenna. and its usually the smallest wire connector located by the power and ground wire. this wire goes to the solid blue wire coming out of the deck. you can conect the wires together any way you want. i usualy shave off a little pice of the wire cover and wrap the wire coming from the amp around the bare wire then cover it in electical tape or cut the blue wire from the deck at a fit length and use a wire nut and put the two cut ends in and also the wire coming from the amp. also make sure the amplifire dose not have power to it just to be safe. wouldent want to fry anything.
There is also the left and right wires(ususaly red and white) that go on the back of the deck to the amp.
also chek the volume on the amplifire
Apr 12, 2009 | Phoenix Gold XENON 600.1 600 Watt...
Amp problem
could be one side of spk voice coil bad if they ar dualor rca problem
Mar 29, 2009 | Blaupunkt PCA465 Car Amp
JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Apr 16, 2008 | JVC SP-PW100 Subwoofer
New car speakers cut out when I turn up the volume.
You just have to check all of the speaker wiring.It's a wire touching somewhere and it will do that till you fix it. What it is is just where the negative wire which is the ground for your spreakers it's touching the positive wire which is know as a power wire.When this happends it lowers the frequency of the volume which will cause the speakers to cut out and volume level to drop.
Dec 20, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
Car Audio & Video Logo
80 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
