Question about Kyocera FS-C5015N Laser Printer
After 2 and half year, the colors starts to shift aside one another (red is not exactly on yellow, wich is aside blue, etc...). What shall I clean or change to resolve this problem? kyocera_fs_c5015n laser_printer
  • 241 Answers
You will need to perform a color registration. Direction on how to perform this is in the advanced manual page 2-87. Use this link to for the manual http://ca.kyoceramita.com/americas/jsp/upload/resource/16793/0/FSC5015-5025-5030ENOG-ADV.pdf
Posted on Jun 09, 2010
SOURCE: How do I set IP
Press the Menu button on your printer and use the up and down arrows to find Interface. Press OK and use the up and down arrows until Network appears than press OK again.
Use the up and down arrow keys to now get to TCP/IP and press OK. Now you should have a sub menu that includes DHCP, BOOTP, and IP. Select IP and use the left and right arrow keys to move between the numbers of the IP address and use the up and down arrows to change the numbers.
For you reference this can be found in the advanced manual (found here-http://tinyurl.com/6m5s2h) on page 58 or section 2-32.
Henry
Posted on Apr 30, 2008
  • 66 Answers
SOURCE: Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Posted on Sep 20, 2009
  • 62 Answers
SOURCE: Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Posted on Feb 01, 2010
  • 167 Answers
SOURCE: my kyocera FS-C5015N printer is
Reclean the cyan corona wire/grid with the cleaning block that comes with each toner.ensure that you leave the corona unit as far out of the machine as possible for 30 seconds to allow the grid to dry.If this does not work then you will need a technician to attend to the printer.
Posted on Aug 10, 2010
  • 29 Answers
SOURCE: kyocera fs-c5015n laser printer printing red
So were the pages are supposed to be blank it has a red tint to it?
If this is the case sound like the developer unit for the magenta is bad you have to replace it if this is the case.
Posted on Aug 24, 2010
Color code on isuzu rodeo 2002 ls
You should have a plate or sticker under the hood on the firewall on the drivers side that lists the color code. With many manufacturers there may be several variants to the stock color throughout the model year so it's possible that even with the color code your final color may not match exact, but it will be close. If you're still not able to find the color code on your vehicle, try removing the fuel filler door and seeing if your paint supplier can camera match it for you.
Apr 02, 2014 | Isuzu Rodeo Cars & Trucks
Image Color problem
Yes. and look at the color wheel for a residue build up too. Use alcohol to clean it with a cloth that will not leave lint behind.
Jan 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Color diagram for a clarion radio
If this is a factory radio - the year would be required.
However just before 2000 model year... and for a couple years after - the following wiring colors are prettymuch constant....
Constant 12V+ Red/White Switched 12V+ Red/Yellow Ground Black Illumination Green/Red Dimmer Red/Yellow Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Blue Left Front (-) Yellow Right Front (+) Green Right Front (-) Gray Rear Speakers 4" Roof Mount Left Rear (+) Orange Left Rear (-) White Right Rear (+) Orange/Blue Right Rear (-) Orange/White
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 07, 2010 | Clarion Car Audio & Video
Blue convergence is shifted right slightly
CHECK FOR THE SUFECE MOUNT CAPACITORS AT THE SMALL CONVERGENCE CIRCUIT BOARD
Jul 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Dec 08, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
HP880c missing colors
you need to go to preferences and adjust the new cartridges, aline, clean, etc.
Jan 06, 2008 | Office Equipment & Supplies
Kyocera FS-C5015N Laser Printer Logo
398 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
