Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
I have a Ge refrigerator (model # PDS22MIsacc) it seems to be running alright, but the temperature control panel will not light. we are unable to change tempertures.
    President:
  • 2,468 Answers
You will need to replace the main control board located on the rear panel behind an access panel,this board controls all temps and digital readouts,when the readout goes dark this board is the culprit
Posted on Apr 27, 2010
Major ice build up on the freezer side of the side by side TFX20JRSM model RL257174. Defrosted the freezer side, seems to be working alright but the refrigerator is not cooling properly. The temperature is...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ff
Sep 26, 2010 | GE Refrigerators
Temperature and adjust refrigerator panel does not work.
problems exist in its electronic control panel that is damaged, this problem should be solved by replacing one block electronic circuit in the control panel. damage is usually caused by a memory of the troubled program. actually if you know you can fix the electronic control panel of the electronic circuit itself, simply replace the IC EEPROM or memory alone. follows with Cristal oscilator usually must be replaced too
Jul 24, 2010 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerator temperature control panel not lit. This happened last week but corrected itself....not sure how....but now display panel is off for good, it seems. Main Refrigerator lights are still working,...
Your Refrigerator Has a main controlboard located in the rear of the machine. This Controlboard sends power and reads the user information. if your user display (Temp Control panel) is not working it can only be 2 things The user display or the main controlboard.
As far a the refrigerator working without it, I would not trust it.
The clicking noise is a relay on the main control.
Usualy when I here this relay go on and off rapidly, there is a problem whith the main controlboard.
The big problem with this is why did the main control go out ? some other componet on the refrigerator could be the cause. A comon cause in the past has been the evaperator fan motor.
Jan 15, 2010 | Refrigerators
We have a gsh25jftfww ge fridge. the temperature control panel (on front) does not light or work and fridge and freezer is not cooling. The light is still on in the refridgerator, but fan is not running...
Your refrig uses a main control board that is on a recall list .The board uses a WR55X10552 . The replacement board is WR55X10656 . I would suggest calling GE factory service and they will cover this under warrenty , due to the recall .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature control panel beeping
There are 3 models with this model #,so not sure if your has lock.
If it does and still changes,contact ge and tell them what is happening,maybe they will send you out a new control panel,if the warranty expired,depends.But it doesn't hurt to try.
This feature allows you to lock the controls
so the settings cannot be changed.
To lock the controls:
Set the controls to the desired settings.
Press and hold the lock pad for
3 seconds.
When the controls are locked, the indicator
light will come on and the control settings
will not be displayed.
To unlock the controls:
Press and hold the lock pad for 3 seconds.
After unlocking the controls, the settings
will be displayed, the lock indicator light
will go out and the settings can be changed.
Apr 14, 2009 | GE PTS22LBN Top Freezer Refrigerator
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
GE Profile does not run.
Just to be sure... check your owners manual to see if this unit has a "showroom switch". It's a little switch that turns off the compressor, etc. but lets everything else light up so the sales persono on the showroom floor can show it off. Some customers have hit the switch to "on" during cleaning by accident.
Sep 29, 2006 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
146 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
