Question about Skeetervac SV-3100 Mosquito Exterminator
My skeetervac starter botton doesn't click anymore so I can't the skeetervac started.
The battery is brand new and when hook it up and turn the key the neutral light and the hot light come on but when I hit the start button it clicks and doesn't click anymore. Not even turning over. Th
Remove battery terminals and clean both posts and terminals
with sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to current flow both into and out of the battery. Charge the battery as not all batteries are charged sufficiently when new to do the job. Also not all new batteries are good batteries as they suffer manufacturing faults which allow them to discharge internally. some batteries are sold without the acid so check that is not the case.. Check all terminal connections including any earth wires.
Jul 15, 2013 | ATVs
Skeetervac mosquito exterminator
I have a large pond in my backyard and get really bad mosquito's. I think that the machine might have a short in it. I got so sick of trying to fix those machines that I think I am going to start calling exterminators. I hear it works so much better too.
Norah ' http://www.cal-rid.com/en/about_us.html
Jun 17, 2013 | Skeetervac SV-3100 Mosquito Exterminator
Truck has power but doesn't start. Starter doesn't click either
Have you checked the circuit between the key switch and the starter ?
There should be a starter relay and a neutral safety switch involved.
Feb 25, 2013 | 1994 Toyota Pickup
Car doesn't start, starter clicks
Hi Dave,
I see that you mentioned the starter clicks but will not start the car.
Check Battery connections, clean the contacts to be sure, also if still it does not start the car try a known good battery.
I hope this helps, have a nice day.
michaelvincentc
Aug 31, 2012 | 1999 Chevrolet Corvette
2003 Harley-Davidson FXSTDI Softail Deuce Starter just 'clicks' doesn't turn engine over happens on occassion Help
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a possible prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jul 26, 2012 | 2003 Harley Davidson FXSTDI Softail Deuce
1991 Lexus 400 - engine doesn't start - battery seems charged - 12.3 volts - makes clicking sound only - doesn't turn over at all.
Is it one click or multiple clicks. If it's multiple clicks, it sounds like a dead battery. Voltage isn't always an indicator of a good battery, you need to have enough cranking amps to be able to start an engine also. If you have dash lights and it only clicks once, you could have a bad starter. An easy way to check this is to try and jump start the vehicle. If it starts up with a jump start, you need a new battery. If it still doesn't start up and it just clicks, you probably need a new starter.
Good Luck!
~Brandon
Jun 01, 2011 | 1991 Lexus LS 400
Took apart the SkeeterVac as it would not lite after the propane was replaced. When we disassembled the gasket fell apart - what can I make a new gasket out of?
I had the same problem. I've located a gasket company but they may not sell to consumers. Don't throw it away yet! I hope to have an answer by 12 Aug.
Aug 02, 2010 | Skeetervac SV-3100 Mosquito Exterminator
MY BIKE HAVED GOOD CHARGE , IM PUSH START BOTTON,
check you starter is working, to activate starter touch a wire from the battery to terminal on starter ,starter should turn..
Dec 21, 2009 | 1986 kawasaki ZL 900 A2 Eliminator
I have 1985 hoda shadow and wont start and when I hit the start botton all it dose it click and click and it wont start
Sounds like bad starter, or bad battery. If the battery is good, most likely bad connection at starter, or starter itself.
Jul 13, 2009 | 2002 Honda VT 1100 C3 Shadow Aero
Skeetervac SV-3100 Mosquito Exterminator Logo
116 people viewed this question
Top Skeetervac Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Skeetervac Pool and Spa Expert? Answer questions, earn points and help others
