Question about Sony CDX-GT100 CD Player
Where can I get a wiring harness for the radio itself? I am not talking about the connection you match up with your year model make of car.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
Try pacparts.com
Posted on Apr 27, 2010
Need wiring harness power and speaker wire that connect to radio.
If you are saying that you don't have the harness that plugs into the radio itself, you will need to visit the website of the particular brand or visit the dealer that carries them. If you are talking about an install harness (which wires your your radio wires and then plugs into the vehicle side of the harness), you can get them at www.crutchfield.com
Aug 27, 2011 | Car Audio & Video
Can I hook up a pioneer deh-p3500 without a harness?
If you are talking about the radio harness, probably not. If you are talking about the wiring harness to plug it into the vehicle. The answer isn't so simple. Aftermarket radios have standardized wiring colors. BUT, they don't match vehicle wiring. So, unless you know your vehicles wiring diagram very well, I wouldn't recommend installing without the wiring harness. If the problem is that someone installed in your vehicle before this and cut the vehicle side of the harness, then I recommend you visit scosche or PAC website to see if it is available. It CAN be done, the question is SHOULD it be done. And the answer is no. Harnesses are very cheap these days, unless you have a data transfer style radio, then it gets a little costly. Most are around $7-$20. Hope this helps
Aug 22, 2011 | Pioneer Car Audio & Video
The Color wires on the car doesnt match the radios wires and when they do match the radio will not play or come on
I recommend that you use a wiring harness to install your radio. Aftermarket wires are standardized colors. Vehicle makes and models will vary so much and the wiring is completely different between them. Also, if you attempt to hardwire, you may fry your entire electrical system. If you are missing the vehicle side of the harness, visit the scosche or PAC website. They may have it. Wiring harnesses are pretty affordable and will take the guesswork out of the wiring. Hope this helps.
Aug 22, 2011 | Car Audio & Video
What do i have do by to make my alpine iva-d310 work insted of being blank
It Depends On What Is Wrong In The First Place... (Note) Make Sure Your Radio Is Hooked Up Correctly! All The Wires Have To Be In The Correct Places for the radio To Function Properly, Its Probably Color Coated So Just Match Wire to Wire From The Radio To The Harness, If U Dont Have a Wire Harness That Matches ur Vehicles Model Or Harness Then U Will Have to Go And Purchase One At Wal Mart Or Best-buy,If U Already Have The Proper Set up And Ur Radio Is Hooked Up Correctly And Its Still Not Working. If U Can Here Sound But No Picture then It Is Most Likely Your Lcd Ribbon That Connects From The Main Unit To The Flip-Out tv Screen, Hope This Helps :-)
Mar 11, 2011 | Alpine IVA-D310 Car DVD Player
Replacing car radio (JBL) with a Pioneer (DVD) Toyota Sequoia
I have used what is called a toyota car harness to iso adapter for this sort of thing .
aerpro APP0141 check at your local auto shop
https://automotivesuperstore.com.au/aerpro-app0141?gclid=Cj0KCQiAtJbTBRDkARIsAIA0a5MqtkIR92nbYhY-M6qqHBjfuaEZVlBE7lJuD_VMtvlU3MCtIRUgNpEaAnfREALw_wcB
it converts your toyota to a international standard ISO and then you buy a Pioneer {whatever model number } to ISO and then you can plug them together and get the radio and car talking to one another.
Jan 22, 2018 | Pioneer Car Audio & Video
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is www.crutchfield.com. Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
How do I install a JVC KD-G140 car cd deck
You  are not in over your head. You just need to make sure you pay close attention to detail when connecting the wires.
First thing to do:  Go to a place that installs car stereos and tell them you need the complete install kit including the wiring harness adaptor. Most all of these places will sell them to you. It is what they use to install the radio. They must know what type of car you are putting it in. Give the the mjake and model and year. They will then give you a bag full of plastic parts and another small bag with a wiring harness. MAKE SURE you get both. You really do need them. The plastic parts are for mounting the radio in the car properly. Without it, you will have something sloppy and it will not look right. It should have instructions. The kit will usually be able to be used for several different models of cars and any model of radio. You must pick which part is right for your car and radio. As I stated, it will have instructions.
Next, after you have the plastic mounting parts picked out for your radio, you will need the wiring harness for your radio and the wiring harness adaptor that you just purchased. The wiring is easy, just match the colors from the harness of your radio, to the same colors on the adaptor harness. Make sure that the wires are stripped properly and they are twisted together properly (or use small wire nuts or crimping type if connectors). Connect red wire to red wire, yellow wire to yellow wire, black wire to black wire, and son on until all wires are connected. Then for extra safety wrap each wire with some black electrical tape to ensure that if a pair if wires came loose somehow that they would not touch anything and short out causing the radio to need service.
Now you just plug the proper end  of the harness into the radio and the other end into the harness in the car that the factory radio was plugged in to. Make sure to plug in the antenna as well. Make sure the cage that the radio is  in is secure in the plastic mounting brackets you have purchased. Then the radio will go right into place and the bracket will screw in where the factory radio used to be screwed into.
If you need more help, just ask.
Dave
Jan 20, 2009 | JVC MXKC45J
Radio connection Pioneer vs Subaru Forester
I would like to refer you to a reputable car audio dealer.
If you have NOT yet CUT THE FACTORY HARNESS, DON'T!!!!!!!
Airbags are nothing to take lightly...
I HIGHLY RECOMMEND a wiring harness adapter from a reputable source such as METRA, Scoche, or Pozitive Connections. Every wiring harness adapter changes the colors at the "pioneer side" of the harness to color match the PIONEER RADIO. All you have to do is color match, plug and play.
HOPE I HAVE HELPED.
Scott
Sep 27, 2008 | Pioneer DEH-2800MP CD Player
How to wire in the receiver
what type of car is it and year model you should be able to by a wiring harness for your car and the wire colors from the radio to the harness should match
Feb 08, 2008 | Car Audio & Video
Sony CDX-GT100 CD Player Logo
75 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
